Thanks for having me back
straylight
#1 Post by straylight »
Been a while, tried to login, alas, my old nick "straylight" was no more. So I re-registered and looks like I have it back. Hopefully. Sentimental.
Bit of an update, sadly the sprint hasn't been on the road for 6 months, the shame, the shame. But took her out last monday for a bit of a run. Seems I'm leaking diff oil into the rear hubs, so work needed there (awesome forum resources for doing this btw) and more worrying is the intermittent electrical cut out. Driving along, steady revs, and the engine dies. Full fuel filter and it is too sudden to be a starvation issue. Comes good after 5-10 seconds and sometimes accompanied by some awesome backfires. Intermittent, seems good for 10-15min, then plays up again.
<sigh>
facebook is okay, but tbh, nothing beats the information that is collected in these forums.
I miss Jonners, seems weird reading the threads he contributed so much to :(
stu
Re: Thanks for having me back
#2 Post by xvivalve »
Check your battery connections, if they are ok, try the plug at the back of the ignition switch. You can get an awesome backfire by switching off he ignition whilst driving.
I know what you mean about Jonners, I’m still visiting his house once a month or so, and there’s a real empty space there!
Good to see you back here!
Aye, it is good,......
#3 Post by sprint95m »
Welcome back Stu.
#4 Post by Mad Mart »
Hi Stu, welcome back. :bluewave:
Check the fuse connections as well. Get a bit of wire wool on them to make sure they are making good contact.
#5 Post by MIG Wielder »
Hi Stu, Just a couple of other things to check when the engine dies in this mode.
( You may have to be quick to do these checks before the dodgy connection comes good again ).
* Is the oil pressure light ON when the engine dies and stops, and as an additional check does the Handbrake light work OK ?
If so then the white cable wiring from the output side of the ignition switch is O.K. and you can concentrate on ignition coil related stuff.
* Does the heater blower motor work and also the washers ?
If so then the fused side of the IGN ON wiring is O.K.
* Does the hooter still work ?
If so the fused side of the always-on-12V supply is O.K.
* Do the headlights still work ?
If so the unfused side of the 12V always on wiring is O.K
After that its the battery connection/ earth leads / and the multiway connector block.
Galileo
#6 Post by Galileo »
Straylight? Awesome club tune by Baxter Baxter about 10 years ago, when I still frequented such places..!
straylight
#7 Post by straylight »
Thanks for the quick suggestions about the ignition....onto it. I need to trace out my ignition kill switch anti-theft circuit, I found the switch !
Thanks for the warm welcome back. I am on FB if you want to hit me up. Member of the official FB page.
Galileo....straylight - from the "Villa Straylight" - Neuromancer :), with a side reference to spectroscopy.
Sundowner
#8 Post by Sundowner »
Stu,
I have no advice regarding your Sprints "issues", but its great to have you back.
Cheers cobber,
Rob
Galileo
#9 Post by Galileo »
straylight wrote: Fri Jun 14, 2019 2:36 am Galileo....straylight - from the "Villa Straylight" - Neuromancer :), with a side reference to spectroscopy.
Brilliant! That never occured to me, I want to change my handle to Wintermute!
Just to be actually useful, my Sprint coughed and died in a similar way a few months back, thought it was the rev counter that was the cause but mysteriously the ignition feed in the fusebox had come loose.
#10 Post by soe8m »
When you are on points and have the original setup you can leave all wiring and fusebox issues. The ballast wire to the coil is directly connected inside the loom. The only thing can be the ignition switch feed or the ignition on wire out. But when your probleem occurs and all other functions still work then the ignition switch and feeds are also ok.
Jeroen.
gmsclassics
#11 Post by gmsclassics »
Yes, welcome back. Good to hear from you. It must be the season for brake drums full of oil - I'm in the middle of fixing mine, which I only found when rotating the wheels. Gearbox nose seal 141756 is a better replacement for the one in the axle, but I'm changing outer seals and bearings as well given it hasn't been done before in 120,000 miles!
Geoff
straylight
#12 Post by straylight »
Good diagnosis. I recall now that when I parked up and went for a restart, the engine fired but cut out shortly after, when the pressure on the key was released. Points to the ignition key switch. I'll look at it this weekend.
I have a replacement modern fusebox.
Thanks again, I need to spend more time in intelligent discussion on a forum and less time on the rubbish facebook.
stu
