It is currently Sat Feb 29, 2020 4:21 am
Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 1 2 3 4 5 611 Next
PostPosted: Mon Aug 05, 2019 2:34 pm
You could use adhesive velcro Murdo, that might make it easier?
PostPosted: Mon Aug 05, 2019 2:43 pm
Thanks Tony, but to get the carpet tight onto the cills I think adhesive would be better, as that's what was used originally, but need the best one for the job - hence my apprehension of just using any.
Murdo DA
RNK 957W, Triumph Dolomite Sprint.
Club Membership No: 2017092
PostPosted: Mon Aug 05, 2019 6:09 pm
I see what you mean now Murdo. This the stuff i have used in the past and it seems to do the job.
https://www.ebay.co.uk/itm/Premium-Adhe ... 8b57c568de
PostPosted: Mon Aug 05, 2019 9:22 pm
How many more times will you want to change (or remove) the sill carpets?
The 3 stuck on bits (2 sills and across below the back seat) are pretty much sacrificial anyway. After YEARS of use and completely knackered, it's still hard to remove the originals, let alone get them out intact! The ones in my Sprint shell are actually in really good nick, it's just a shame they're the wrong colour! I'm going to try getting them out in one piece, if only to serve as patterns for new black ones!
I tend to use good old fashioned Evo-Stick in brush on, rather than spray on, form (more controllable) Does what it says on the tin!
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
Spectrum Auto Services, Servicing, Repairs, Electrical, Recomissioning, MOT prep, Trackerjack brake fitting service.
Apprentice served Triumph Specialist for 45 years and home of Maverick Triumph.PM for more info or quotes.
PostPosted: Tue Aug 06, 2019 9:41 pm
I'm needing 2 of the floor blanks where the rear seatbelts anchor if anyone can help.
If you mean the black, plastic bungs that seal the holes where the bolts go when rear belts are fitted, I may be able to find you a couple. They are quite hard to remove intact as they are throw away once the bolts are fitted. But I have a couple of scrappers I can raid!
Yes, those are the ones, needing to fit two as original owner had a child seatbelt fitted.
Found a pair! PM me your address again Murdo and i'll get them off to you!
PostPosted: Thu Sep 05, 2019 9:35 pm
I've not updated the thread for a long time, but here's the door cappings back from Chapman & Cliff, the photo doesn't do them any justice, they're top notch.
Murdo DA
PostPosted: Fri Sep 06, 2019 8:13 am
Wow! they look great.
2007 Porsche Boxster S
Grammar:
Schedule: Pronounced "Shedule" not "Skedule"!
PostPosted: Fri Sep 06, 2019 11:58 am
The glove box door wasn't done, it's just there so you can see the match, it's actually a perfect match, it's the camera that's changed the light some how.
They asked for that to be sent down too so they could use the correct laminate, what a top professional job they've done
Murdo DA
PostPosted: Fri Sep 06, 2019 1:05 pm
I've not updated the thread for a long time, but here's the door trims back from Chapman & Cliff, the photo doesn't do them any justice, they're top notch.
I have seen a lot of their work Murdo, as they are only a couple of miles from me. Superb workmanship but expensive..... But you get what you pay for :D
On the same Industrial estate there is a small body shop that will fabricate and repair most panels on any classic car. And again on the same estate a sprayer that is on par with the best of them.
PostPosted: Tue Sep 10, 2019 5:24 am
TDC West Yorks Area Organiser
This is now looking like a "resto" thread. Shall I move it there?
1972 Dolomite 1850 auto (NYE 751L - Waiting for me to give it some love)
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the workhorse)
1995 BMW 318i (M265 PNC - Project Bimmer, the 2nd car)
1991 Toyota Celica GT (J481 ONB - the current project car)
"There is only one way to avoid criticsm: do nothing, say nothing and BE nothing." Aristotle
PostPosted: Tue Sep 10, 2019 10:36 am
Hi Toledo Man, it's not a restoration though just maintenance.
99% of the car was only taken apart for cleaning thoroughly.
The car is totally original as it came from the factory with only having had an external respray to refresh it, door cappings refreshed, bumpers rechromed, new rubber seals and wheels refurbished and that's the total extent of the work, all covered under good care and maintenance.
:thumbsup:
Shortly I'll be adding photos of the untouched original floor with all the carpet glue removed, and having had a light polish, then the original carpet will be refitted.
Murdo DA
PostPosted: Wed Sep 11, 2019 6:00 am
It might be better off in the "resto" section. Not all the threads in there are restorations as such.
PostPosted: Thu Sep 19, 2019 12:23 pm
Brilliant thread (and car!) Murdo, truly. I see very few Sprints (if any) where I live, let alone an auto and white one !
I especially appreciated the moving description of Pat's life story, wonderful reading mate, thanks for that..
PS the wood restoration looked absolutely brilliant too, well worth the effort!
1976 Dolomite Sprint (Mimosa Yellow)
PostPosted: Thu Sep 19, 2019 2:04 pm
Cheers mate.
I'll need to re-add some of the photos via another source, as Photobucket have blurred their use for some reason.
Murdo DA
PostPosted: Tue Nov 26, 2019 9:23 pm
I'm going to try and keep updating the page now that I've found another way of uploading the photos...……. I'll need to delete all the previous ones as photobucket have put their logo across them all :bash: here's some when I started fitting the headlamps seals, bowls etc.
Murdo DA
Users browsing this forum: No registered users and 5 guests
