Hello , after moderator suggest , i try to sum up my issues :
i am a Lucky guy who have two dolomites with head problems
the 1850 had a broken head gasket , but the head was already overskimmed . So i :
-put an other one with small modifications ( water holes oversized to match with block )
- improvement of the radiator , with three lines in
- new bottle cap with pressure test .The setting was not ok on the new cap , i had to modifiy it to get the good pressure
Now everything looks alright , i will check the torque in a few days , after 500 kms .
the sprint looked to have the same problem , while engine retrofit
-bottle cap was faulty : pressure too low
- head off , Nothing broken on the gasket
So we decided to do a pressure check to the head , and we found a leak in an inlet port
we will do a pressure check to an other head i possess , as soon as possible , and put an improved radiator .
1850 and sprint head issues
Re: 1850 and sprint head issues
this should be useful , for other users , thanks to Marshman who shared it
- min-head-thickness.jpg (49.75 KiB) Viewed 674 times
Hello,
Would these figures also count for the TR7 heads?
Regards,
Luke.
Regards,
Luke.
Well.....
