It is currently Tue Apr 16, 2024 9:34 am
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Dolomite Nismo
PostPosted: Thu May 14, 2020 12:04 pm
Uh oh, you'd better get the shell over here Richard! :lol:
PostPosted: Thu May 14, 2020 1:20 pm
Richard
Before i upgraded my front hubs to Stag ones , i had those hub spacers fitted on my sprint but i found i couldnt set them up properly even using all the shims supplied
PostPosted: Thu May 14, 2020 2:59 pm
I bought 2 sets of mounts and cut the studs off one set, allowing me to get the engine in exactly the right place before drilling the hole in the subframe and then swapping to the other set with the studs.
That's genius. Should see the 'slotted holes' I have on my engine-swapped car as a result of doing it the hard way. Best mate still hasn't let me forget about them..
Looks like a fun project!
PostPosted: Thu May 14, 2020 3:55 pm
Richard
Are you using Sprint or Stag stub axle pins.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Member TDC no 0471
PostPosted: Thu May 14, 2020 4:18 pm
Richard
Phil
The guy i bought mine from he made them , think he got the size wrong , i know he does them for the Stag was well , mine were for Dolomite and Dolomite stub axle ,ive not fitted any to the Stag setup on my Dolomite maybe in the future
Dave[ /color]
PostPosted: Thu May 14, 2020 5:03 pm
The pins are different lengths between the two.
The Stag pins are longer.
I’m not sure if the wheel bearings are the same as I Just swapped it all over.
So possibly have got the wrong size.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Member TDC no 0471
PostPosted: Thu May 14, 2020 5:43 pm
Phil
No when i did the hub bearing spacer mod on the sprint every thing was standard,even bought new wheel bearings timkin , thats why i think the hub spacers were machine wrong,at the time they didnt do the spacer kit for the dolomite , he made them for me
PostPosted: Sat Jun 06, 2020 5:37 pm
So the car is now with me for some bodywork, cleaning, modifications, exhaust! :lol:
The shell is great, just needs a few rust repairs, sills boot floor, front panel, wing repairs. Nothing major, then a few modifications for Richard.
On the face of it the sills looked ok, especially the passenger side, but after cutting them off the extend of the rot could be seen.
I was hoping that the front end of the sill would be ok but I'm not that lucky!! :lol:
I just used my usual process for dealing with sills, strip everything off and start at the back working out and reconstructing. The only difference is that I had to remove a section of the tread plate upper outer to do a proper repair on the inner reinforcer.
New jacking points
New reinforcer
Outer welded back on
Club sill fitted
New front sill made
Linished, rust protected and seam sealed
Front and rears repaired
Done, on to the other side.
PostPosted: Sat Jun 06, 2020 8:46 pm
James
Youve done a few sills now :D is it common for the sill step to rust through , both mine have rusted just in front of the rear doors
when you replace the inner sill at the bottom are the club inner sills have a right angle bend, or are you putting that in, the middle part of the sill why do you fit a right angle to them and not weld straight to the bottom edge
thanks Dave
PostPosted: Thu Jun 11, 2020 11:25 am
James
thanks Dave
Sorry Dave, I wasn't ignoring you, just forgot you replied!
I havent seen many but the other side of Nina had done the same on the inside of the bottom curvey bit.
Julian asked me pretty much the same question, does this help?
https://forum.triumphdolomite.co.uk/vie ... 45#p329649
PostPosted: Thu Jun 11, 2020 6:36 pm
On to the other sill, this side was bad at the rear as well as missing the front jacking point.
This was all that was left of the rear section and jacking point! :lol:
A standard repair, including some repairs to the trailing arm mount behind plus new jacking points and lower sill section.
The seatbelt mounting reinforcers have been extended and attached to the lower inner sill.
The rear of the reinforcer has been repaired and angless section fitted to attach it to the inner sill.
Then I had to stop, unfortunately my welding torch burnt out! No suprise really, it's had some abuse! A new rather swish, much better one is arriving tomorrow!
PostPosted: Sat Jun 20, 2020 7:48 pm
New torch and new return lead arrived so I could finish off the club sills, sorry about the second photo I keep forgetting to take pics!
On to the inner front valence so I could get the shell up onto the rotisserie.
The outer was removed to give me access to the inner, also so I can repair the outer later on
It has the usual rust!
Using the club repair panels I cut off the ends and treated all of the surface rust
Test fitted the panels, the silver paint is weld through zinc rich primer.
And with the click of a finger they are on! 8)
A coat of Upols finest zinc primer and some stonechip later and the club inner valence panels are fitted! This is one of those really satisfying jobs, the old panel was a bit of a state and now thanks to the hard work of Alun getting these panels made it looks new.
On to the rotisserie we go!
On its side set to 45 degrees gives me perfect access to the inner rear wheelarch!
On to the last of the rust repair jobs, next is to repair the boot floor with a club repair panel
PostPosted: Sat Jun 20, 2020 10:01 pm
Great stuff James.. that new toy of yours is really helping you here.
Do you use 0.6 or 0.8mm welding wire out of interest?
Kind Regards
MC
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
PostPosted: Sat Jun 20, 2020 11:14 pm
James
nice work be ,interested in how you repair the rear arches mines gone it the same places also boot floor as well gone
when you fit the club sills cant see from your pictures , do you cut the bottom edge where it folds back on its self
PostPosted: Mon Jun 22, 2020 6:38 pm
Kind Regards
MC
0.8mm Matt, 0.6 just isnt worth bothering with!
James
Which edge is that Dave? At the top? No, I have used a bead roller to create an edge, lap jointed it to the top then ground back the welds to create an invisible seam.
Users browsing this forum: No registered users and 23 guests
