It is currently Fri Apr 19, 2024 3:35 pm
Post new topic  Reply to topic  [ 258 posts ]  Go to page Previous 112 13 14 15 1618 Next
PostPosted: Thu Jun 04, 2020 1:02 pm
Where do you PUT all your stuff? You know, tools and spare parts and anonymous junk?
Tools are all stored in drawers, cupboards and bench shelves, which aren't seen in these photos, the larger stuff is against the wall under the dust sheets.
I have a shed for all the parts, which is handy as couldn't have them littering the garage :lol:
Triumph Dolomite Sprint,RNK 957W
Club Membership No: 2017092
PostPosted: Thu Jun 04, 2020 1:06 pm
It looks really good!
Personally I wouldn't bother with the engine bar support thing. You have a lift (yes I am a bit jealous!! :lol: ), a perfect opportunity to just drop the engine and box out in one go then whilst the engine and box are out you can detail them. Plus the other areas that you can't get to.
Pull the exhaust, prop and gear lever, disconnect the speedo and any hoses and brake lines. Drop the lift, disconnect the rear gearbox mount, 4 subframe bolts, support on 5 axle stands then just raise the car up leaving the engine on the floor. It would probably take me less than an hour to do.
Whilst I was at it, I'd pull the axle at the same time!
Not wanting to teach you to suck eggs but watch it if you pull the engine you'll make the car rear heavy on the lift.
If I had your skills James and ability I would certainly be doing that :thumbsup:, but a lack of confidence leaves me doing things very slowly, and a lot more time consuming, but I'll get there before I retire :lol:
You can fully rebuild a car in a few weeks, nothing scares you, just get stuck in.
I was warned about the weight ratio thing a long time ago when I was rebuilding my Landy. That was very light in the rear and very top heavy at the front, so really conscious about that now - thanks for the heads up though.
Haha no worries Murdo, as far as I can see you're doing a good job. Just take your time and the most important thing is to enjoy it!
PostPosted: Thu Jun 04, 2020 3:11 pm
I'd be pleased if my local HOSPITAL paid as much attention to cleanliness as you do in your garage Murdo.
I fear mine will never be that clean, i never even got round to screeding the concrete floor, it was pressed into service too quickly and as a result, I have a bit of a dust problem (ignoring the general mess that is also a constant presence)
I am convinced Murdo has a daily help that comes in every day Steve :lol: :lol:
PostPosted: Thu Jun 04, 2020 5:04 pm
I can get as many as are needed. Have you a photo of the ones on your heater blower to see if they're the same as mine, 3 x stickers on the blower
Hmmm. This is the blower I am overhauling
And this fine beauty is the blower it was to replace :lol:
It wasn't far off that bad when I started the job 9 years ago. How time flies. The car is a 1980 1500HL so likely it had the same stickers as yours.
I wonder, have we ever had a survey of the different under bonnet stickers across the range and years on this forum?
At the risk of seeming pedantic, the screws you've used look wrong. I got some stainless ones that are an exact match to the originals, they probably came from Stainless Automotive Fastenings.
PostPosted: Thu Jun 04, 2020 9:09 pm
At the risk of seeming pedantic, the screws you've used look wrong.[/url][/b].
If you want a set I can get a set made for you.
I have the correct self tapers, but just not at hand when I fitted the bits together.
PostPosted: Thu Jun 04, 2020 9:14 pm
The help's not been in since the lockdown.
PostPosted: Thu Jun 04, 2020 10:58 pm
I didnt know there were stickers on the heater
PostPosted: Tue Jun 09, 2020 6:15 pm
I'm stripping the front suspension and subframe off the Sprint for cleaning up just now, and pretty sure it's the original shocks that I've taken off, as there's no receipt for their replacement.
Not bad for 40 years.
PostPosted: Wed Jun 10, 2020 6:32 pm
Got the rocker cover back from powder coating and very pleased with it, it wouldn't polish up so got it done.
Got the original washer bottle and bracket cleaned, the dishwasher did a great job of the bottle, I robbed the new strap and foam off a Rimmer's one.
PostPosted: Thu Jun 11, 2020 10:34 am
Very nice Murdo :thumbsup: Very brave using the dishwasher, my mrs still wont let me forget time i used our dishwasher to clean parts :( Never again :wary:
PostPosted: Sat Jun 13, 2020 3:32 pm
I went through a cardboard box this morning that came with the car. I didn't think there of was anything of much of use in it, but amongst other things, I found four sets of points (still to check they're Sprint ones), 6 new alloy wheel nuts, 4 new wheel studs , but the photos below was the best of them all, Pat's Rimmer's discount card, must be quite old as there's no "1" in the telephone number, something else to add to the history of the car. When was the one introduced.
There was also a brand new car cover, but it's made of stuff that will sweat badly, and probably the reason it's still in it's original bag - I won't be using it either.
PostPosted: Sun Jun 14, 2020 10:20 am
16th April 1995 apparently.
PostPosted: Mon Jun 15, 2020 10:09 am
That roughly coincides with when he bought the stainless steel exhaust off them, there's a receipt from 1993 for it, so likely he was given the discount card then. The exhaust still has the Rimmers label on it, label must be made of good stuff lasting 27 years... :lol:
PostPosted: Mon Jun 15, 2020 12:47 pm
I quite often find these Rimmers labels on stainless exhausts fitted to cars that have passed through my hands, even the one that was fitted to my own Sprint (off the road since 94, so fitted before then!) had a couple on the silencers.
PostPosted: Mon Jun 15, 2020 1:20 pm
I had a couple on the silencers.
What's surprising is, this one is on the first silencer box, so the hottest, must be asbestos paper lol.
Users browsing this forum: Bing, Majestic-12 [Bot] and 65 guests
