Structural adhessive
cleverusername
#1 Post by cleverusername »
Having run out of welding gas and needing to repair a hole in the scuttle, I thought I would give structural adhesives ago. It seemed like an attractive option. No heat distortion, no risk of fires, no need for a welding helmet and other safety equipment. The only downsides appeared to be the need to put the patch on using a large overlap and joggle it in.
All seemed to go well, secured the patch and seamed sealed round the edges. Till today. when I found a leak. Now I had to remove the dash to weld up the windscreen surround on the other side, so I had good access. The water was seeping round the patch. It took very little effort to remove it with a screw driver and I was able to peel it off.
Now I know there are demonstrations of structural panel glue in which it shows a great deal of strength. I am also sure with correct curing temperatures, pressure and joint design, it can be just as strong as welding. However as an alternative to welding for classic car repair? Sorry not convinced, I will be breaking out the mig tomorrow to repair the scuttle properly and based on my experience I wouldn't trust structural glue for DIY repairs just yet. It seems too easy to make a repair which looks strong but in reality isn't.
SprintV8
Re: Structural adhessive
#2 Post by SprintV8 »
What where you using.
Use a Wurth product in the past and you couldn’t break the joint.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
dollyman
#3 Post by dollyman »
Tiger seal is another good one.
cleverusername
#4 Post by cleverusername »
dollyman wrote: Thu Dec 24, 2020 1:33 pm Tiger seal is another good one.
Tiger seal isn't a structural adhesive and using it to a attach a panel is not a good idea.
dollyman
#5 Post by dollyman »
cleverusername wrote: Thu Dec 24, 2020 2:30 pm
So long as it's non load bearing and you prepare both surfaces, it's fine.
new to this
#6 Post by new to this »
You could try panel bond (its a 2 part mix adhesive)
cleverusername
#7 Post by cleverusername »
new to this wrote: Thu Dec 24, 2020 4:40 pm You could try panel bond (its a 2 part mix adhesive)
The stuff I used was bondloc metal to metal, which is two part. The product seems to have been discontinued, which could explain the poor results.
new to this
#8 Post by new to this »
cleverusername wrote: Thu Dec 24, 2020 5:22 pm
The Panel bond ive used in the past was made by 3m Panel bond its about £40
cleverusername
#9 Post by cleverusername »
new to this wrote: Sun Dec 27, 2020 7:09 pm
I have got a bit interested in this and one thing I've discovered is panel bond is not the same as structural adhesive. Structural adhesives are impact resistant, panel adhesive is not. A bodyshop could actually get in serious trouble if they used the incorrect one for repair of a modern car.
Of course when it comes to the Dolomite, I have no idea if such systems would be allowable for body repair.
