...are the codes for the felt seals which go inside the front hub and seals the stub axle.
I need a set for my rebuilt subframe.
Question is, has an uprated seal kit been used or recommended. Felt just seems so last century darling
I’m setting up bearing spacers and the guy who’s selling them says that the replica felt seals are way too thick and don’t allow you to set up the bearings properly.
Does anybody have a couple of spare original seals ?
He changes his mind with the weather,he says use Timken bearings, i did mine came with the felt seals, i steel couldnt set mine up, like i said before im sure hes made them the wrong size,
when i first bought mine he said he didnt have any or the Dolomite,he had Stag ones and he was going to modify a set
ive given up on mine now,he ended up getting me to buy two sets of wheel bearings and still on joy
I believe the difference between the Stag and Dolomite is length.
Stag uses a longer stud axle pin so guess the spacer is longer.
Think I saw somewhere about Ken using or making these bearing spacer kits.
New To This.
If you have a spare Stag kit I could be interested.
As mines running Stag hubs.
1980 Dolomite Sprint with a touch of BLTS Balanced Lightened and Tweaked 13B Rotary and SsuperCharged.
Back in my possession 22 September 2019. Rebuilding the Sprint time taken so far, 111Hrs@15/12/2020
212Hrs @31/12/2021 352 @ 28/11/2022 455Hrs @ 20/10/2023 565Hrs @ 07/12/2024
Member TDC no 0471
SprintV8 wrote: ↑Sun Jan 17, 2021 10:58 am
New To This.
Yes the Stag does use a longer stub axle,my kit was made up for the Dolomite so wont fit Stag hubs,but i know some one with a new stag kit not fitted ,he now has upgraded to alli hubs and bigger stub axle using the bigger wheel bearing on inside and out,i can ask him if he wants to sell his bearing spacer kit
I may also up grade my hubs to the alli hubs and bigger stub axle
Where are the hubs coming from Rimmers/Chris Witor ?
Could you set up the spacers without the felt pads.
Once all set then refit the felt pads.
Believe the spacers lock the inner races.
So end float would be set with the spacer shims.
Member TDC no 0471
