Ball Joint GSJ133 - Obtaining a replacment boot
bazyerma
Re: Ball Joint GSJ133 - Obtaining a replacment boot
#16 Post by bazyerma »
matt of the vivas wrote: Tue Jan 19, 2021 10:04 am They are an odd sized boot. The club ones fit fine.
Hi Matt,
Have you fitted one yourself, do it look like my one in the photo?
Regards
Barry
Aberdeen
#17 Post by Mad Mart »
Barry, The dimension into the groove is 41.4mm. diameter. The club boots cost £2.99 that includes a couple of cable ties.
bazyerma
#18 Post by bazyerma »
Mad Mart wrote: Tue Jan 19, 2021 12:07 pm Barry, The dimension into the groove is 41.4mm. diameter. The club boots cost £2.99 that includes a couple of cable ties.
Hi Mart,
Thanks for check, as below on mine the groove is 48.38mm, so sadly the club boot would be too small.
I think I will go for below.
https://www.ebay.co.uk/itm/UNIVERSAL-TR ... SwHc9epIjI
Barry
Upper ball joint Groove.jpg (198.47 KiB) Viewed 1113 times
Aberdeen
mahony
#19 Post by mahony »
bazyerma wrote: Tue Jan 19, 2021 3:09 pm
Hi Mart,
Barry
You sure your measuring into the groove ? , Looks like your measuring the outside of the ball joint :D
bazyerma
#20 Post by bazyerma »
mahony wrote: Tue Jan 19, 2021 3:30 pm
Hi Mart,
Barry
Hi Mahony
I assure you I am, even if not, the grove is not going to be 3-4mm deep. The tapered edge of my Vernier is in the groove, I know its a ALDI cheapy but its not that bad!
Regards
Barry
Aberdeen
mahony
#21 Post by mahony »
bazyerma wrote: Tue Jan 19, 2021 3:47 pm
Hi Mart,
Barry
Hi Mahony
Regards
Barry
Okie dokie 😊
marshman
#22 Post by marshman »
I checked a couple of old ball joints I have and also my selection of different sized ball joint boots.
The ball joint I have measures the same:
48.2 mm to bottom of groove and 19.3 mm across the bottom of the taper pin.
I have a new boot (part of a selection, not specific to the Dolly upper ball joint). This measures 38.5mm on the lip that sits in the groove and 14 mm on the top hole.
You need to remember rubber stretches quite easily and quite a lot!!!
I tried it on the upper ball joint and it is a very nice fit - a bit of a stretch on the bottom but once on it doesn't want to slip off and that is with out any clips or cable ties.
Any new boots I have used on any joints have always been smaller than the actual joint and stretch over. This ensures a good seal. Use ones that measure the same size and you run the risk of dirt getting in because when you fit the wire/clip/cable tie it will "ruffle up" possible allowing small gaps to which will allow moisture and dirt to get in.
Finally, I would trust what the club is saying, i.e. their ones fit! - £25 a year for a club that has good quality spares as well as a decent forum is not a lot to pay - the magazine is not a bad read either.
I have attached pics I took this afternoon - the fitted boot is the one I measured.
Roger
1971 Stag Auto White
#23 Post by Mad Mart »
My measurements come from a rebuildable ball joint so may be slightly different. The groove is 3mm. deep.
NewNewBall Joint.jpg (97.82 KiB) Viewed 1082 times
bazyerma
#24 Post by bazyerma »
Hi All
Well success with my eBay boot. The joint seemed good s I decided to drill and tap the housing and pump it full of grease.
I am rather happy with how it turned out, sadly I have the other side to do now! :lol:
Regards
Barry
Stand off
Stand off
Ball joint - fitted with nipple - Stand off.jpg (157.24 KiB) Viewed 1051 times
Fitted with nipple
Fitted with nipple
Ball joint - fitted with nipple.jpg (150.23 KiB) Viewed 1051 times
Drilled and tapped
Drilled and tapped
Ball joint - Drilled and tapped.jpg (193.7 KiB) Viewed 1051 times
Boot fitted
Boot fitted
Ball joint - boot fitted.jpg (186.3 KiB) Viewed 1051 times
Aberdeen
