Downloadable templates for repair panels
I am in the process of digitizing all of the templates that I have with the ultimate aim of allowing users to download and print them out 1:1 for their own use, cut them out, stick them to a panel etc...
This may take a while, I have a lot of templates!!
I will try and update this post accordingly over the coming weeks.
Instructions for printing the pdf templates:
Download and open the appropriate pdf file, some larger pieces may be spread across two pages/files.
To print ensure that you select print Actual Size
When you have printed the file you can verify the size by measuring the white and black Scale, each block is 10mm long by 5mm wide, if this is correct then the file has printed to the correct sizing.
- Headlamp Support Panel Brackets v1.pdf
- Headlamp support panel spacer brackets
- (1.4 MiB) Downloaded 502 times
- Headlight Gasket Support v1.pdf
- Headlamp Gasket Half Moon Part # 627242
- (1007.9 KiB) Downloaded 452 times
Re: Downloadable templates for repair panels
Brilliant idea!! Appreciate the time and effort this will take, but really useful.
One tiny ask/suggestion - can you write the metal thickness on the template. Will save a lot of time trying to measure thickness, I know there will be standard thicknesses for body and "chassis" parts but I can never remember!
Roger
Roger
1971 Stag Auto White
Good idea, I'll do that, thanks Roger.marshman wrote: ↑Fri Jan 29, 2021 1:59 pm Brilliant idea!! Appreciate the time and effort this will take, but really useful.
Roger
Hmm.....
This is quite an undertaking.
Well done James
Well done James
- Saving up to join the Club!
james what a good idea...let us know how progress is going...deserves a big pat on back and well done
- soe8m
Can I have some Allegro templates as well?
First template uploaded, let me know how you all get on
Announcements:
In the process of writing the instructions for the Support panel brackets
Jacking Points - original and Club sill modified
Jacking Pads
All to be uploaded Thursday
Version History:
12/02/21 - Uploaded Headlamp Support Panel Brackets V1
Jacking Pads
Version History:
Brilliant Idea!
i was making a headlight suround panel today and thought it would be easier if there was an online template.
Keep up the good work James
Thanks chaps, I'm still in the process of working through them. It's taking longer than expected, mainly due to having to teach myself AutoCad!
You could also try some TR7 ones!
Russ Cooper
Dursley
UK
Dursley
UK
I've been using the older style CAD.... Cardboard Aided Design.
Back in 1994, when I was still officially registered as unemployed, I took a Konver Scheme funded, City & Guilds course in AutoCAD 12, at Chelmsford College of Further Education, but I have never since had the opportunity to use AutoCAD!
https://cordis.europa.eu/programme/id/REG-KONVER-2
https://hansard.parliament.uk/Commons/1 ... nverScheme
Regards.
Nigel A. Skeet
Nigel A. Skeet
