I seem to have developed a distrusting nature, whilst recommissioning my old dolly 1500hl. I'm at the stage where I'm rebuilding the engine and am of the opinion to build it right for a bit of longevity. So after many hours of research i am no better off trying to find quality parts for the bearings and timing chain, sprockets and tensioner. I have seen the rollson tensioner debacle (for the OHC engines) and want to avoid that. I'm going with the Payen gaskets and am having it balanced and blueprinting the oil pump as well as fitting a 1300 grind cam, hardened valve seats with a 3 angle cut and a 10.1 CR measured.
So basically, I'm asking if I buy from Rimmers or Canley ect a standard simplex chain, sprocket and tensioner, will I have problems
Also recommendations on basic mods and decent bearings would be greatly appreciated. I'm not going for a grenade, just a reliable engine with a little more power than std.
Kind regards, Luke
