It is currently Fri Apr 19, 2024 9:33 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: Re: Sprint turbo
PostPosted: Sat Jan 15, 2022 10:40 pm
There was a blue one on that Aussie site years ago (May be 15 years ago) and this Spitfire…
PostPosted: Sun Jan 16, 2022 12:41 pm
If i go ahead with turbo,ill go for log type exhaust manifold,when i made the inlet manifold i used 45mm tube, but when i checked the exhaust manifold gasket yesterday,i think you need a big diam tube,but room is tight
PostPosted: Mon Jan 17, 2022 2:16 pm
As an alternative to the turbo-charger, how about the supercharger route to the same end. Moss do one for the MGB and if it fits that, then a Sprint shouldn't be too difficult with a bit of machining.
The big problem is the price..... £££££££ (lots). :shock:
https://www.moss-europe.co.uk/catalogse ... percharger
PostPosted: Mon Jan 17, 2022 2:42 pm
supercharging would be the better option in my opinion, simply because you're not using exhaust gases to drive it.
As Carledo suggests, the reasons not to do it far outweigh the reasons to do it(other than it being an interesting engineering exercise of course)
i think intercooling it sufficiently would also be a significant challenge within the constraints of a Dolomites packaging.
i'd love to see someone try though!
viewtopic.php?f=19&t=23031
Proud TDC Member!
PostPosted: Mon Jan 17, 2022 4:19 pm
Like this…
https://triumphowners.com/to-car/supercharged-dolly/
PostPosted: Mon Jan 17, 2022 8:07 pm
There dear
PostPosted: Mon Jan 17, 2022 8:13 pm
Dont think ive got enough room on the right hand side of my engine EFI plenum in the way
PostPosted: Tue Jan 18, 2022 2:28 pm
There dear
you're going to be in for this kind of money if you want to do it without it blowing up
Proud TDC Member!
PostPosted: Fri Jan 21, 2022 10:07 pm
But go ahead and prove me wrong if you think you're good enough!
Come on Steve, that's not like you to be arrogant! I'm sure you didn't mean it that way. :D
Didn't mean to come off as arrogant! I'd kinda like to see it done, just as intelectual engineering interest!
Problems offhand to start with,
The block isn't strong enough, particularly round the centre main web
The crank isn't strong enough (spend enough on tuftriding and stress relief and it MIGHT be)
The conrods aren't really man enough.
The standard compression ratio is too high.
The way the head is secured isn't really up to turbo combustion pressures
Ditto the head gasket.
The cam design doesn't allow for variations in cam timing between inlet and exhaust for max benefit.
Internal engine cooling isn't good enough, a turbo will generate almost twice as much heat as NA.
Packaging IS the big one though. No matter how you slice it, there is no WAY you can get a turbo near enough to the head to avoid massive lag. Roger's simple suggestion of reversing the manifold won't work, the holes don't line up. And in any case the turbo needs to be more or less in the middle or the pulse pathways are all different lengths. So, unless you are willing to have the turbo poking up through the bonnet like some American dragster, it's a bit of a non starter.
The final nail in the coffin is that there are at least a half dozen purpose built turbo'd engines that WILL fit the hole, deliver decent and reliable power increases and cost a lot less (and deliver more) than anything you can do with the Sprint lump. Yes it was cutting edge tech in it's day, but that was 50 years ago, engines have moved on since then!
I reckon you can get it in, using a log manifold as per the spitfire. Equally, being a supercharger fan, with much experience in fitting these to other stuff, again i reckon it could be done.
But everything you say about the engine shortcomings wont go away. Its just not a good starting point. Especially something with an unstable cylinder head / block joint!
Just because something can be done, doesnt mean you should! There a reason all sorts of other stuff is getting fitted.
1970 Triumph 2000 Estate w/ RV8
1980 Triumph Dolomite Sprint
2003 Holden Ss Ute
1969 Dodge Charger
1973 Triumph Stag
1961 Standard Atlas
Users browsing this forum: No registered users and 40 guests
