1500TC Restoration Progress
Mark1500TC
#1 Post by Mark1500TC »
My 1500TC has turned into a bigger job than first envisaged 🤣🤣
I’ve been working on the body work over the summer and resprayed the complete car in Cellulose, it’s come out pretty well, probably a few more polishes to get it shining nicely.
Now tackling the underside on a body roller ( great piece of kit!).
Just sent the prop shaft off for refurbishing and got the wheels / rocker / timing cover back from Redditch Powder Coaters ( highly recommend them).
So not far off now starting to put all the bits back on the car, complete with new carpet set that was in a bag with the car when I got it!
Hopefully see some of you on the stand at the NEC show when I visit there.
New carpet set
New carpet set
Car in process of Respray
Prop shaft sent off to be refurbished and balanced
Mark1500TC
Re: 1500TC Restoration Progress- more pics
#2 Post by Mark1500TC »
A few more pictures from my first post
Aye….
#3 Post by sprint95m »
They always end needing way more work AND money than
first envisioned :D
Is that Maple?
Ian
Mark1500TC
#4 Post by Mark1500TC »
Yes it is Maple Brown- the paint shop used the code and mixed it no problem 😀
triumphdolomiteuk
Site Admin
Site Admin
#5 Post by triumphdolomiteuk »
Bostin' :thumbsup:
Mark1500TC
Re: 1500TC Restoration Completion
#6 Post by Mark1500TC »
After 2 1/2 years after my last post, Ive almost completed my 1500TC Restoration :D
JVA had its first MOT in 20 years to make sure all was well and I had put it all back together correctly, the garage did the Headlight Alignment & the tracking and it passed. :D
It appears to drive well, the one issue I seen to have though is with the clutch; the biting point is very low to the floor! I installed a complete new clutch from Rimmers, a refurbished Master Cylinder and a new (refurbished) Slave Cylinder from David Manners. Today Ive had the car on ramps and removed and bled the slave cylinder, refitted pushing it in the housing as far as I can, (the retaining bolt dictates this), put it all back together and unfortunately no apparent improvement?? I'm sure I fitted the clutch correctly as I double checked everything?
Has anybody else had the same issue with a 1500 (or 1300 as I understand they are the same slave cylinder?) Any advise welcome!!
