Concentric clutch slave
new to this
#1 Post by new to this »
Im converting my Sprint clutch slave cylinder to a concentric slave cylinder, does it make any difference what size bleed nipple i use ? thread size of the bleed nipple i mean M8 or M10
Thanks Dave
cliftyhanger
Re: Concentric clutch slave
#2 Post by cliftyhanger »
new to this wrote: Sun Oct 30, 2022 10:30 am Im converting my Sprint clutch slave cylinder to a concentric slave cylinder, does it make any difference what size bleed nipple i use ? thread size of the bleed nipple i mean M8 or M10
Thanks Dave
Nope, my CSC has a braided hose and a tiny remote bleed nipple. Thread must be 6mm, maybe smaller.
The only ting to be concerned about is setting the distance up correctly, and allowing for clutch wear.
new to this
#3 Post by new to this »
cliftyhanger wrote: Sun Oct 30, 2022 11:47 am
Thanks Dave
Thanks for reply Dave
cleverusername
#4 Post by cleverusername »
Are you sure you want to do this? I have had no end of problems with concentric slave cylinders on modern cars. Too many duff Chinese parts about that fail very quickly and being inside the bell housing they are a real pain to replace.
new to this
#5 Post by new to this »
cleverusername wrote: Wed Nov 02, 2022 6:52 pm Are you sure you want to do this? I have had no end of problems with concentric slave cylinders on modern cars. Too many duff Chinese parts about that fail very quickly and being inside the bell housing they are a real pain to replace.
There be less moving parts, hoping ill be okay :) :)
