https://forum.triumphdolomite.co.uk/vie ... 9&start=15
https://forum.triumphdolomite.co.uk/vie ... =4&t=37524
I've done the valve clearances on the workbench. I've used 10 thou per the camshaft thread and unearthed TriumphTune spec sheet. The head has probably only been skimmed about 20 or maybe 22 thou. I will be using an extra thick head gasket +20 thou so really in terms of valve proximity to pistons these two effects more or less cancel out.
Two questions I'd really appreciate some thoughts/advice on :
1. The head is back together and I just need to source a few different shim sizes to revisit and conclude everything. Current shim sizes varying between 100 and 112. But see photos. I knoooow everything I'm doing around this is merely dealing in thou's and the valve stem length is what it is .... but those valves feel like they are sticking out so far they would surely hit the piston.
Paranoia.
Nevertheless, does this look right?
2. Just two bolts hold the camshaft to the camshaft sprocket. They aren't even very long. This just seems a crazy weakpoint. In my case the bolts are OK. But if I did want to replace them where would I get them and are they some special high tensile spec?
I'm thinking they must be.
I only managed to track down the part number from an old Sprintspares catalogue. SH604041. Is that correct?
So for example this https://rimmerbros.com/Item--i-SH604041 or https://robsport.co.uk/index.php/online ... -1-2%C2%94
But do these meet the spec?
