VA138, the next chapter....
shaunroche
Re: VA138, the next chapter....
#181 Post by shaunroche »
A messy workbench for a change but I've made up the hydraulic clutch pipes and mocked up the system to test it to make sure it works and doesn't leak.
It does, and it doesn't :)
RSi
#182 Post by RSi »
shaunroche wrote: Thu Feb 16, 2023 6:20 pm A messy workbench for a change but I've made up the hydraulic clutch pipes and mocked up the system to test it to make sure it works and doesn't leak.
How are you going to connect them when the gearbox is in situ.
Club Membership No: 2017092
new to this
#183 Post by new to this »
RSi wrote: Thu Feb 16, 2023 9:05 pm
You can see the two hoses sticking out of the Bellhousing, one will go to the clutch master cylinder and the other will be a clutch bleed valve
shaunroche
#184 Post by shaunroche »
new to this wrote: Thu Feb 16, 2023 10:03 pm
Is the correct answer.
#185 Post by tony g »
What slave cyl did you use? I have a saab one on mine, just wondered if theres another that fits. Looking very nice :)
RSi
#186 Post by RSi »
shaunroche wrote: Thu Feb 16, 2023 10:23 pm
Would it have been better to have the join just outside the box, just wondering - if a leak sprung it would be easier to fix.
shaunroche
#187 Post by shaunroche »
RSi wrote: Fri Feb 17, 2023 9:14 am You can see the two hoses sticking out of the Bellhousing, one will go to the clutch master cylinder and the other will be a clutch bleed valve
The ideal solution would be to drill holes in the top of the bell housing and use bulkhead connectors but I didn't want to do anything to the gearbox that was not reversible in case the rubbish cross shaft system needed to be reinstalled for whatever barmy reason.
In my experience, as the fittings are the same size and type as the brake pipes, I've never had one leak and the leak I did once have was down to one of the pipes splitting due to the gearbox and engine being taken out about 5 times trying to cure yet another engine oil leak - where these pipes exit the gearbox I have put a thick tie wrap on the inner and outer side and this has stopped the pipes moving about, once the engine and box are installed in the car I don't expect to take them out again.
new to this
#188 Post by new to this »
shaunroche wrote: Fri Feb 17, 2023 10:09 am
What i did on my setup, fitted the Aeroquip hoses straight in to the clutch cylinder and used 25mm pipe plugs in the gearbox where the cross shaft went and hoses poke through the pipe plugs
shaunroche
#189 Post by shaunroche »
The hoses were already made up and had I plumbed them directly into the cylinder then they wouldn't have been long enough...you need to post some pictures Dave!
gmsclassics
#190 Post by gmsclassics »
I used a similar setup on my racecar in 2013. I use a small piece of heater hose to protect the pipes where they went through the gearbox casing. I took the bleed pipe back up to where the clutch master reservoir is and attached with a cable tie. Never had a single issue with it. Excellent product. Geoff
IMG_1031 (2).JPG (64.44 KiB) Viewed 27138 times
PaulB
#191 Post by PaulB »
Hi Shaun,
Is it a Sprint Speed cylinder?
shaunroche
#192 Post by shaunroche »
PaulB wrote: Sat Feb 18, 2023 3:44 pm Hi Shaun,
Hi Paul, yes it is.
You can buy the cylinder fairly cheaply by using a Saab one, but there is a fair bit of machining required on the aluminium bits it is mounted to so that's where the cost comes from I suspect.
shaunroche
#193 Post by shaunroche »
Wasn't overly happy with the paint finish so the car's been back in the Spray booth recently, I'm picking it up later so we'll see how good it is....
RSi
#194 Post by RSi »
If you're not happy with it, quite right!
new to this
#195 Post by new to this »
This is how I did mine
