OHV intake manifolds (single carb)
Bunji
#1 Post by Bunji »
Does anyone know how many different types of single carb intake manifolds were used across the OHV range (including Spits)?
And what size runners each type has.
1972 Toledo 4 door "Betty"
cliftyhanger
Re: OHV intake manifolds (single carb)
#2 Post by cliftyhanger »
UK only the "log" type fitted to the dolly 1300, and the curly type fitted to heralds. Saying that no idea about what the FWD cars had.
The log type is a more advanced design. This stuff is worth a read. The first is written by a very clever chappie, and john is a bit of a genius.
https://forum.tssc.org.uk/topic/5565-si ... ment-67873
https://www.tssc.org.uk/tssc/uploaded_f ... 201998.pdf
John Kipping (who is in new zealand somewhere) did lots of stuff with carbs, he found twin strombergs to be the most economical, but he really liked a single 1 3/4" carb on his 1500 heralds.
The single carb will naturally give a smoother cylinder fill, as it has a even/continious intake flow. Twin carbs are constantly on/off, which will not be as good, but they have other advantages. (firing is 1342, or start at the end, 21 34. Front carb feeds 2cylinders, then rear carb feeds 2. A crossover manifold would be better, but very complex, just look at the single weber dcoe crossover inlets)
