Door Bottom
new to this
Door Bottom
#1 Post by new to this »
On My passenger front door the bottom has rusted away, while im repairing it the channel that holds the door seal is also missing, any one know where i can buy that channel ?
thanks Dave
Re: Door Bottom
#2 Post by xvivalve »
Wadhams Rover specialist in Stourbridge sells straight lengths of it
DOLOMITE 135
Re: Door Bottom
#3 Post by DOLOMITE 135 »
Chris Witor sells lengths of steel channel for the triumph 2000 range which I think is the same as the Dolomite range, probably worth a call to confirm if no luck elsewhere:
https://www.chriswitor.com/proddetail.php?prod=CW3927
new to this
Re: Door Bottom
#4 Post by new to this »
Thanks for the replies ordered some from Chris Witor ? just got to finish the rust repair on the door, done one half, the hardest bit is the corners so meany different shapes
Macleesh
Re: Door Bottom
#5 Post by Macleesh »
Seam seal them once fitted to eliminate the water trap!
1977 1850 HL manual O/D
new to this
Re: Door Bottom
#6 Post by new to this »
Macleesh wrote: Tue Nov 14, 2023 9:47 am Seam seal them once fitted to eliminate the water trap!
Thats what I'm going to do, plus I'm fitting more and better drainage holes in the door
ClassicFan
Re: Door Bottom
#7 Post by ClassicFan »
new to this wrote: Tue Nov 14, 2023 7:02 pm
Once done give the inside a good coating of Bilt Hamber Dynax to stop the rust getting hold again
GlenM
Re: Door Bottom
#8 Post by GlenM »
[/quote]
[/quote]
If that's the Dynax S50 you are referring to, it's brilliant stuff. I used it inside some box sections on our horsebox that I had repaired, there were quite a lot of plug welded flange joints, and it's so liquid that it crept into all of them. However, once dried it sets quite firm and is very durable.
ClassicFan
Re: Door Bottom
#9 Post by ClassicFan »
GlenM wrote: Sat Nov 25, 2023 6:06 pm
Yes Dynax S50, I also use SC (which is nearly clear) on outer sections e.g. engine bay. It was recommended to me by an engineer who worked on North Sea oil rigs. Ferrosol is also far better than WD40 and very effective on alloy parts....
new to this
Re: Door Bottom
#10 Post by new to this »
finished the rust repairs to my passengers door, fitted part of the door channel waiting for the rest to come
