Subframe dimension question..
shaunroche
#1 Post by shaunroche »
I know this information will be in this Forum somewhere, but I can't find it!
The rear Subframe bush holes, do we have a minimum dia dimension that these should be please?
I ask as the ones on my subframe are a bit frayed and I'm wanting to get them repaired.
Cheers!
Re: Subframe dimension question..
#2 Post by xvivalve »
The holes on the NOS subframe I have here measure 30 mm. diameter
shaunroche
#3 Post by shaunroche »
xvivalve wrote: Wed Dec 20, 2023 12:00 pm The holes on the NOS subframe I have here measure 30 mm. diameter
Thank you Alun, you've restored my faith in the Forum!
I've had them repaired and the rear holes are now considerably less than that!
#4 Post by xvivalve »
I've repaired them in the past by welding the same washer that sits beneath the subframe bolt head to the top of the dome and then grinding back to shape; that too creates a smaller hole but one that I know the bolt can pass through.
