It is currently Tue Apr 30, 2024 2:28 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Sprint Ignition
PostPosted: Fri Mar 31, 2023 8:33 pm
TDC Kent Area Organiser
Terry.
If money is not a problem, go for a 123.
My Sprint has been in storage since October last year. I have not started it for three months. Three turns of the key today it fired up, and idled at 800rpm like it was started and running yesterday.
The 123 is a superb bit of kit that is hard to beat.
The down side is they are pricey.
Richard.
Richard, I was looking at the 123 option but the adapter problem put me off.
Yours looks very neat so how did you manage that please?
Russ
Russ.
A 123 distributor made it for me in Holland. Happy to pass on their details. Brilliant people.
Sent them the old Lucas which they used as a template.
R.
Sprint, ;- DBL 532V
PostPosted: Fri Mar 31, 2023 8:51 pm
the 123 is imo an expensive alternative for the so not talented mechanic.
its still a dizzy (for people who prefer the classic look and who demand modern electronic, this might be the "only" reason to invest):
why i say this:
its still a rotating dizzy with a cap, a finger , a sparc which has to jump from the finger to the cap.
a dizzy-less solution like Megajolt or Nodiz is the "modern" way to go:
full electronic, no rotating parts, no wear parts but you need some knowledge in fabricating and spannering (installing a trigger wheel to the crank pulley for example)
so if you have the money, if you prefer an easy installation and if you are not so talented in fabricating: go for the 123
if you a good inspannering: got for the Megajolt or Nodiz.
if you are on a tight budget: go for a simple hall-effect module.
this said: both full electronic solutions (Mega and Nodiz) can be extended by a TPS, where you than have a full 3D mapping available.
3d Ignition with the correct mapping will really change such an oldschool engine.
Ask the Ford Escort or the Kitcar-Guys....most will tell you "installing the 3D ignition transfered the engine in a way that i thought i gained 10-15BHP"
I have to correct this, true the 123 dizzy has a cap and rotor but that is where the similarity to a normal dizzy begins and ends. the 123 has no mechanical bobweight advance, the REAL bugbear of old school distributors, instead it has a fully mappable setup inside like the best Megajolt/Nodis systems.
Because of the design of the Sprint engine, where the jackshaft drives the distributor, which, in turn, drives the oil pump, it is impractical/impossible to delete the distributor entirely, even if (as I would) you go for a crank sensor and EDIS.
So you might as well make the most of this design oddity and use a 123!
PS We used Mahesh's 123 fitted Sprint on the 2018 RBRR, 2166 miles in 50hrs 1 min. It performed faultlessly, went like a train and averaged 43mpg over the distance. And that's still on SU carbs. Its a brilliant bit of kit and well worth the expense IMO!
Mahesh has the cleverest cost option, bluetooth connectivity that lets him tweak the map from his PHONE!
thats true...same applies at Ford´s SOHC (pinto) powered cars....you need to leave the dizzy (or some remaings) fitted to drive the oilpump. but plenty of owners still convert to 3D ignition (Megajolt or Nodiz...mappable via Smartphone as well)....i must admit that the 123 thing is more common in the Triumph and MG community, than at Ford´s.....you hardly find Escorts or Cortina´s running with 123.....as you can see from my words, i´m originally a "Ford-Man"...now in the Triumph world.
Hi
I have to add I disagree on the Ford front as well. 123 all the way for me.
They simply take the cars to new levels with reliability, performance, and through being Bluetooth being able to be adjustable immediately if needed.
The other benefit is you can disable the 123 dizzy so you also have added security. Unless you re-mobilize the 123 before starting it up, it’s difficult for anyone to nick your car.
My Escort is shortly also getting the 123 conversion.
I cannot say enough good words about the 123.
Richard.
Sprint, ;- DBL 532V
PostPosted: Sat Apr 01, 2023 8:57 am
Hi
Richard.
3D Mapping using Megajolt , Nodiz or whatver other brand brings the car to "real" new levels with reliability, performance etc.
Nodiz is as well connectable via Bluetooth...only advantages without the disadvantage of having a rotor, a cap and moving parts.
and with Pinto engined cars, with some (curved)intake manifolds used in spaceframed cars (like Formula Ford, Kitcar World, Locosts etc), there is limited access to the dizzy, so another advantage to go dizzy-less ignitionwise.
the 123 is good if you want something modern with easy installation or if your skills dont allow fabricating (which is obviously necessary when going 3D)...but Performancewise the 3D, Dizzyless Solution is, theoretically, THE only way to go.
if you want a simple, effective and economic "fit&forget" solution, not changing / adjusting points anymore: go for Accuspark
already such a simple device will tansform the car in terms of : starting, idle, torque...and usually you can already "hear" it due to a changed exhaust-sound...usually sounds more volumetric.
PostPosted: Tue Apr 11, 2023 4:21 pm
Rimmers tell me that they have not got a 123 Electronic Ignition unit. The only one they found was RKC638EL part number which they said was for a 1300 or 1500 Triumph. I have put a question into 123 Ignition but does anyone know what the right part is for a Sprint?
Terry
PostPosted: Tue Apr 11, 2023 4:25 pm
Further update, 123 Ignition have just replied that they do not have a unit for my car!
Help anyone?
Terry
PostPosted: Tue Apr 11, 2023 10:38 pm
Help anyone?
Terry
Terry.
There is not a 123 off the shelf to suit a Sprint. You either get an adaptor fabricated or use a 123 supplier that can fabricate the adaptor for you.
Richard.
Sprint, ;- DBL 532V
PostPosted: Wed Apr 12, 2023 11:31 am
When I got the Spitfire tuned recently (old-school rolling road tuner) the guy doing it rated the 123 in terms of tune-ability, but had recently experienced issues with warranty fixes on 123 units he'd supplied to his customers, so now recommends that if a customer wants a 123, they source it so he doesn't get stuck in the middle if it fails.
PostPosted: Thu Apr 13, 2023 2:05 pm
some further words against 123 (sorry guys):
my new car (Triumph MK2 2500S with PI Head and PI Cam) was formerly fitted with the latest model of 123.....the car never run right, even after months of testing different ignition curves and settings, we could not found a satisfying result. fitted old dizzy with accuspark-module...the car runs better than ever.
my mates car (Triumph MK1 2000, now fitted with a 2500 engine, with increased compression and PI-cam): he recently aquired this car....the former owner had a 123 dizzy ftted (the older model) and the car feels really "poor" in power output.
same as me: my mate spent hours for testing differtn ignition settings until he fitted a classic-dizzy with accuspark-module and the car is now running with good power output, equal to mine.
PostPosted: Sat Apr 15, 2023 7:00 pm
Does anyone have the design for the 123 adapter, so I could get one made?
Thanks.
PostPosted: Sun Apr 16, 2023 9:43 am
It's a bit like my grandmother did overhaul my engine and never got it running right. It's understanding and reading and checking. The pre set types with the 16 curves do start at tdc when crancking and when the revs are above 500 iirc it swaps to the desired advance btdc at idle. When setting those types statically at idle timing, at idle it can be 20+ degrees and when revving it adds also ofcourse. One of the most common faults and you have to use the correct installation manual because these 123's are not all the same. And check with the stroboscope if the desired idle is correct with the engine running to be sure you did fit it correctly. The 16 curves to choose from are known data and those are std Lucas curves so are the same as the std. dizzies.
You can't blame products on installers faults or lack of understanding. It seems to be popular choosing internet quotes that suits certain idea's. You have it wrong here so can be others on other forums also.
PostPosted: Sun Apr 16, 2023 4:21 pm
i´m talking here of about 3 experienced persons in classic-car spannering....and i dont think that all 3 can be so wrong?
so, all those 3 persons, spannering since 35y (each) on classic cars have no idea what they do, never done it right...so thats why they experienced, independantly from each other, that the 123 did not gave them satisfying results in terms of power-output?
i have installed several dizzy-less ignition systems from Megajolt....and i remain with my opnion: 123 is expensive and not as flexible as it should be. thats why i say: go dizzyless or remain with Accuspark (or a similar tehnology).
PostPosted: Sun Apr 16, 2023 8:50 pm
Yes. My daily job is sorting out problems with classics and half of the problems are caused by experienced experts. Some experts send their customers to me. Also some modern car dealers when computer says yes but the car says no. Experts and 35 years experience has no value for me. Some experts do things wrong for over 35 years. Programming a curve is nothing more than programming a curve. When programming it exactly as the original dizzy to have it running like original is for some already problematic you say. Let alone setting it optimal for that particular engine. My 2500 with 123 runs perfectly. 1.9ms spark and all even. When you understand engines and ignitions it isn't that hard.
PostPosted: Mon Apr 17, 2023 8:48 am
Thanks.
PostPosted: Wed Apr 17, 2024 9:14 am
I don't suppose there has been any movement on the 123 dizzy adaptor has there?
Manufacturing / design details so we can get them made etc
Steve M
68 Triumph Vitesse convertible
79 Dolly Sprint
PostPosted: Wed Apr 17, 2024 4:13 pm
Terry.
Richard.
Russ
I think Richard has done the donkeywork, collaborating with one 123 supplier to make a model specific 123 dizzy for the Sprint. so no adaptation/conversion parts needed any more. Just swap the original drive gear to the new 123. Think he also paid the development costs so the next ones MIGHT be a bit cheaper! Thanks Richard!
