Sprint fuel filler cap
Re: Sprint fuel filler cap
This one is completely different from mine, but thanks.
What you can do is to take the rubber seal out and then cut a groove across it to let air in and then replace it. I do not think many MoT engineers actual look at the seal and it is no different from having a vented cap.
Another Sprint owner suggested I drill a small vent hole through the alloy and up towards to lock, inside the rubber ring. I did and it works. I have another non-vented one I can use for the MOT. Thanks for your suggestion too.
