JGJ - 1975 Dolomite Sprint
RSi
Re: JGJ - 1975 Dolomite Sprint
#31 Post by RSi »
So neat but wouldn't expect anything else.
Club Membership No: 2017092
GlenM
#32 Post by GlenM »
Looks very good James.
In one of your posts, referring to fitting the sills, you said "I am going to do this a slightly different way from what I have done in the past so bear with me here!" Is this the way that you have attached the new outer sill to the top part of the old one? I seem to remember that you normally fit the top of the new sill under the horizontal threshold part of the old one, whereas this time you have fitted it over the vertical face just below the threshold. I imagine this way it is easier to keep the correct line of the sill along the length of the car.
James467
TDC Sprint Registrar
#33 Post by James467 »
I normally drop the inner sill lower Glen. I then extend the seatbelt reinforcements and jacking points down and use some folded steel to join the reinforcer panel to the inner sill. This means that I can retain the upper fold on the outer sill.
It all really depends on how bad the upper part of the sills, jacking points and inner sills are.
Car has been turned around and rotated, am having a tidy up today in preparation for tomorrow. The other sill is original and looks much better, however, given the internal state of the NS I am expecting much of the same on this side.
James467
#34 Post by James467 »
Turned around ready for the other side!
This side is much better, still needed opening up though. There is more wax protection in this side which probably helped somewhat.
You can see the water line on the sill, the rear did have some small holes.
I can get away with a small repair at the rear of the reinforcer
The front isn't bad, but does need repair.
Looking down the inside it all looks fine, I think a spray with some rust converter at the rear, let that dry then a good spray of some Dynax S50 and it will stop that rust in its tracks.
Again, here at the rear jacking point you can see where the water has been sitting, I may have to replace the rear section of the inner sill, there's no point in me doing the whole thing. I'll see how it is after I remove the crushed jacking pad.
A clean up, small repair to the rear of the reinforcer and I can fit a new club sill. Then just a repair to the front nose and I'll fit the wing bottom, four new jacking points and it can go onto the dolly for the rear panel replacement!
new to this
#35 Post by new to this »
2 or 3 drain holes in the bottom of the sill may help
James467
#36 Post by James467 »
new to this wrote: Wed Mar 06, 2024 8:44 pm 2 or 3 drain holes in the bottom of the sill may help
Yeah, I've been thinking about drain holes and the best way to do them. If not done right they'll just fill the sills with water as you drive along on a wet day and cause more problems than they solve.
James467
#37 Post by James467 »
Repaired the rear end of the sill ready for the outer to go on.
I ended up replacing the inner sill as it was the right thing to do.
Then just did a small repair to the reinforcer, nothing too taxing!
Outer skin is ready to go on now.
GlenM
#38 Post by GlenM »
James467 wrote: Wed Mar 06, 2024 2:25 pm I normally drop the inner sill lower Glen. I then extend the seatbelt reinforcements and jacking points down and use some folded steel to join the reinforcer panel to the inner sill. This means that I can retain the upper fold on the outer sill.
Ok. Thanks James.
James467
#39 Post by James467 »
No progress shots of the sill being fitted I'm afraid, just "here, its finished" photos!
The inside of the sill nose was a bit more rotten than I thought so I'll just be doing the same type of repair to the reinforcer here.
Getting there! :lol:
James467
#40 Post by James467 »
I just cracked on and finished I'm afraid, I wanted to get the car off of the rotisserie for now.
Solid!
James467
#41 Post by James467 »
The rear panel has a dent in it where the bumper mounts. I cannot for the life of me get it out so as I have one I'm just going to fit a new rear panel, I've done these before, it's pretty easy.
I don't know if I have done a how to for this. Apologies for the photos, I only decided to do this how to half way through removing the panel!
First job is the worst! Lay on your back and locate the seam where the rear panel joins the boot floor. Locate and carefully drill out the spot welds, the aim here is not to damage the boot floor panel, you will thank me later! Dont worry too much about the centre brace yet.
Next, take an angle grinder and slice the boot floor next to the bottom folded seam where it joins the lower part of the rear wings, along the red line. Don't worry about trying to seperate the seam at the moment.
Cut around the reinforcer in the middle of the boot floor.
Inside the car cut the inner reinforcer panel away from the corner pieces. The, working outside cut down the outside edges of the outer panel close to the seam. NOT all the way to the top! There's an overlap here that needs separating where it joins the wing. (Photos from VA276 to give you an idea of what it looks like)
Now you should be able to pull off the old rear panel with reinforcer together.
Then I use a belt file to go around and remove the spot welds from the leftover seams and to tidy everything up. You don't have to remove the corner pieces but these had some damage which I wanted to repair so I did.
Ready for a test fit!
Test fit the new panel
Happy with that!!
Fitting in the next post, I need a glass of wine!
James467
#42 Post by James467 »
Fitting!
Get the panel on, clamp it in place along the seams starting at the top, don't worry about the boot floor yet, it will pull round.
Make sure everything lines up, close the boot as well and make sure that lines up.
Then starting at the top I plug weld the seam down each side making sure that the panel remains aligned.
Then I use a jack with some steel box section to lift up the bottom of the panel to meet the boot floor. This is where it pays to be careful and not distort the boot floor when removing the old panel.
Then you can clamp the outer seams in place.
The first thing I do is make sure the centre reinforcer is aligned and then weld that back on, this helps support the boot floor for the next stage. I had to cut out a section of the boot floor to repair here...
Then working inside I just plug weld the boot floor to the rear panel then lastly plug weld (or spot weld if you have a spot welder!) the outer seams on. Followed by the joints around the boot corners.
Thats the outer rear panel on! Now to the inner.
Again, prep the seams, I have a hole punch and use that for my plug welds. The panel can then be bolted to the outer panel to align and secure it.
This is critical, if you mount the panel too low then the boot striker won't align and the boot wont close, so the lip has to be flush with the top of the panel.
What I do now is plug weld the panel closest to where the boot latch striker fits. Fit the striker and close the boot to make sure it engages properly. Mine is tight because the boot seal is quite thick.
If that's all good then go ahead and plug weld the top of the panel to the boot seam.
You can then weld the centre bracket to the panel followed by the lower seam to the outer panel, sorry no photo of that!
Then I fit the boot reinforcer corners...
And you are done! I have just dressed some of the welds that were a bit messy and protected everything
This is an early car so I don't need the later holes that were on the panel
Final thing to do is to coat the seam with some seam sealer as per the factory.
Done, ready for paint!
James467
#43 Post by James467 »
I have just been working from the back of the car to the front finishing off little bits that needed doing, radio aerial delete, small rust holes etc....
The standard A post rust repair...
The door check strap was doing that annoying click when I opened the door so I have repaired the bracket as well as the check strap itself.
James467
#44 Post by James467 »
Chassis leg repair.
I am doing this as a seperate post so it's easily searchable.
Unfortunately the chassis leg has suffered where its been standing outside, again I think water has got into it and just sat rusting out where it was repaired previously. It looked ok from the outside, but after I looked inside with my borescore it didn't look good.
However, it's a great opportunity to show how to fit the club chassis leg repair kit!
It looks ok, but like I said, inside its not great.
See! :lol:
Actually the lower panel is ok as is the tube, the rust hasn't taken too much hold, it looks like its come from the upper part where the battery sits. The usual battery acid leakage then! Pretty typical, NWL has the same problem and I'll be doing the same repair on that so this is good practice.
It looks very drastic! I'm not replacing that part but even if I was I would leave the lower panel in place to keep the alignment correct.
That's it for today, the rust encapsulator has to work its magic
James467
#45 Post by James467 »
Right, an update is in order! I've done quite a bit but haven't been able to post for a while.
Where was I.... ah yes, the chassis leg. Using one of the clubs repair kits I reconstructed the leg. I did have to make an inner wing panel, I didn't want to go and cut up the nos wing I have.
All done, thanks to Alun for that!
On to the front wing
Before...
Cut out the rot and repaired the eyebrow, it wasn't as bad as it looked.
New section ready to be grafted in.
All done, I also repaired another bubble that had blown through the metal.
Wing bottom fitted...
Door gaps and lines look really good
Other wing bottom fitted...
Onto the nose. Before...
Cut out and cleaned up the rust, thankfully there is no damage to the eyebrow, it just needs treating.
Made a repair section. These are quite difficult, they are not straight and flat, there is a slight curve in both directions!
Treated the rust on the inside of the nose, just waiting for this to dry now and I can finish.
That's as far as I am at the moment, but I'm nearly done! I just have the other side of the nose to do and the rear door bottoms and it is ready for paint.
