Clearance Parts from the Club
With the Club having lost access to some long time storage, I have taken short-term custody of some mainly used and some new old stock parts owned by the Club. I am part way through sorting through the boxes and cataloguing them and they will be offered here for Club members to purchase. I will edit the following list as I complete the task or as parts are purchased; if anything takes your fancy, then enquire via the parts ordering system to make sure the part is still available and then pay in the same manner as other Club stock; Proceeds will go to Club funds. Please be aware these parts, if used, are as removed from cars and all parts have been stored in an unclean environment for over a decade. Prices quoted are UK destination postage inclusive but quotes can be given for the extra over required for international carriage.
Prices are for a single item or pair where applicable, the number in brackets shows the quantity available.
• Single Trailing Arm with good correct OE bushes (x1) £25.00
• Single rear radius rod with good correct OE bushes at body end (x2) £25.00
• NOS OE Hub inner seal GHS101 (x2) £4.50
• NOS OE Hub seal GHS162 (x1) £8.00
• NOS OE front crank Seal (x2) £4.00
• NOS OE 1850 Gearbox exhaust mount 159674 (x1) £20.00
• 1850 Clutch release bearing, carrier and operating fork GRB209, 143707, 132080 (x1) £30.00
• Steering rack clamp (x6) £15.00
• Steering rack locating plate (x1) £10.00
• Boot catch (bodywork) (x2) £15.00
• Bonnet catch (bodywork) (x3) £15.00
• Bonnet latch (bonnet) (x2) £15.00
• 1850 heater 'T' pipe (x1) £15.00
• Pair front parcel shelf brackets (x1) £15.00
• Late hazard warning switch (x2) £25.00
• Door stay (rear) (x2) £15.00
• Door stay (front) (x2) £15.00
• Steering column bulkhead bush plate (x2) £15.00
• Front ARB bracket outer (x1) £15.00
• Early grab handle NSF (x1) £25.00
• Early grab handle NSR (x1) £15.00
• Early 1850 speedo (showing 116 miles) (x1) £25.00
• Dolomite steering wheel pad (x1) £10.00
• Black offside door mirror (x1) £25.00
• Accelerator pedal and mounting bracket (x2) £25.00
• NOS Stanpart brake drum 312254 Toledo front (x1) £25.00
• Pair brake back plates Toledo front (x2) £30.00
• Upper wishbone (x8) £12.00
• Lower wishbone (with serviceable rose joint and special round headed bolt) (x2) £20.00
• Car set of brake dust shields (x1) £25.00
• NOS 1850 LH engine mounting bracket 156792 (x6) £12.00
• Single 1850/1500 half shaft hub and backplate (x1) £35.00
• Fuel rail Sprint (x3) £15.00
• Fuel rail 1850 (x2) £15.00
• Pair under dash convoluted vent pipes (x1) £20.00
• Front stub axle (x1) £15.00
• Pair 1500TC 'hockey stick' boot trim (x2) £15.00
• Pair rear lights; good chrome, light damage to one lens (x1) £30.00
• Fuel filler neck pipe (x2) £15.00
• Wiper motor (x2) £25.00
• Under dash vent (mounting holes intact) (x1) £35.00
• 1850/1500 fan blades (x1) £15.00
• NOS NSR wing fillet infil panel (x1) £45.00
• Washer fluid bottle (x3) £15.00
• Battery clamp bar (x2) £12.00
• Rear overhang vent frame (x3) £5.00
• Rear overhang vent (x2) £6.50
• NOS 1500 FWD Idler gear 216505 (x7) £35.00
• Early ignition barrel & key (no switch/loom) (x1) £25.00
• Pair wiper arms (x2) £15.00
• Early indicator/side light lens (very slight stone chip) (x1) £20.00
• Front door hinge (x6) £20.00
• Pair rear door hinges (x2) £25.00
• Dash speaker grille (x2) £15.00
• Auto gear selector (no 'T' handle) (x1) £20.00
• Early side light base with wiring and plug (x2) £25.00
• Late side light base with wiring and some bullet connectors (x2) £20.00
• Late number plate lamp with wiring and plugs but no shroud or lens (x1) £15.00
• Bulkhead mounted washer bottle support bracket with motor (x1) £15.00
• 1850/1500 air intake hose (x1) £15.00
• Dolomite 1300 badge (x1) £12.50
• Dolomite 1850 HL badge (x1) £12.50
• Car set HL tread plates (x1) £30.00
• Pair of Toledo radiator grilles (x2) £50.00 [length increases postage cost!]
• Nearside Dolomite radiator grille (x1) £20.00
• Automatic gear stick surround/coin tray (x1) £15.00
• Behind dash heater box 'exhaust'/splitter (x1) £15.00
• 1300 heater control indicator panel (x3) £10.00
• Steering column nacelle (top half and light switch only) (x1) £15.00
• Pair of high and low tone horns, possibly NOS (x1) £30.00
• SE steering wheel (x1) £20.00
• NOS transmission cover for 1300/1500 fwd PN: 306691 (x25) £25.00
• Offside subframe bracket (x1) £12.50
• NSF quarterlight assembly (x1) £25.00
• NOS NS doorskin for 2 door Toledo (x3) £20.00
• NOS OS doorskin for 2 door Toledo (x3) £75.00
• Late heated rear window switch (x1) £20.00
• 1300 speedo (x1) £25.00
• 1300 fuel/temperature gauge (x1) £20.00
• 1300 dash veneer set ideal for refurbishment (x1) £30.00
There is also a box full of NOS Rists looms with identifying numbers 51240889/218955, but I can't work out what they are for; they have instrument bulbs attached, but there's no multiplug for the waring cluster ...
Re: Clearance Parts from the Club
Well done, a lot of work in cataloging that lot!
Do you have a photo of the under dash vent please, just so I am certain it is the part I am looking for.
Hi
Could you tell me which of the front parcel shelf brackets you have, please.
Cheers Phil
Cheers Phil
Hi,
Can I just ask if by ‘Door stay (rear) (x2) £15.00’ you are referring to the Check Straps?
If you are referring to the rear door check straps and they are available, could I please purchase?
David Embery
David Embery
Yes David, that is indeed to what they refer...but with parts having been taken to a couple of shows since the list was last updated, and latterly without a precise record of what sold, I'd have to look in the various boxes to see what is left...and that involves a trip to Stourport, so bear with...
Cheers. Much appreciated.
Look forward to hearing from you when you have been to Stourport.
David
David
Cancel last. Got sorted at Rimmer.
