Hermatite Red
Tallpaul
Hermatite Red
#1 Post by Tallpaul »
Been looking for gasket seal
Hermatite was a good choice a while back. Cant seem to get hold of it now.
Whys that ?
Re: Hermatite Red
#2 Post by xvivalve »
I think I recall the manufacturer folding 20+ years ago as the industry changed to silicone sealants.
Blue Hylomar is still widely available and they used to do a red version called Hylotyte if you prefer seeing a red ooze as you torque down rather than a blue one...
Tallpaul
Re: Hermatite Red
#3 Post by Tallpaul »
Have you used Threebond .I used regulary on 2 stroke engines good stuff.
I found the silicone ones tend to spue out and nothing left behind on the gasket.
Paul
Re: Hermatite Red
#4 Post by Carledo »
I remember red Hermetite and not fondly either! If I had a pound for every hour I spent scraping the wretched stuff off some mating surface or other once it had set rock hard, I could have retired at 30! I'm GLAD it's not available any more!
I use whatever silicone sealant the factors send me. Or I get really cheap and buy the bathroom stuff from the wholesalers about £1 a big tube. I only buy speciality stuff if the application doesn't normally have a gasket at all.
Re: Hermatite Red
#5 Post by Carledo »
Tallpaul wrote: Mon Jun 30, 2025 5:34 pm Have you used Threebond .I used regulary on 2 stroke engines good stuff.
Paul
That's the whole point, what you don't need spills out and you only use what's needed to make a seal and wipe the rest off. Of course, if you ARE using far too much (most do) on something like a sump gasket, the other half of the too much you used ends up in the sump and the oil strainer, not the best idea!
Most gasket applications need only a light smear, not half a tube!
Re: Hermatite Red
#6 Post by Mad Mart »
This is what I've been using the last few years...
Brilliant stuff although a tad expensive!
Tallpaul
Re: Hermatite Red
#7 Post by Tallpaul »
Ill have a look at that martin..looks expensive :D
Tallpaul
Re: Hermatite Red
#8 Post by Tallpaul »
Just found on that auction site £26 for 473ml not too bad
Slowmo
Re: Hermatite Red
#9 Post by Slowmo »
I use Wellseal on faces with thin or no gaskets, and blue Hylomar on faces with thicker gaskets. I have had good results with both of them.
Peter.
1978 Dolomite Sprint - Inca
