ignition switch wiring
1300dolly
#1 Post by 1300dolly »
does anyone have pics or diagram of the back of a 1300fwd ignition switch?
since fitting mine i have lost the spark/coil feed but i did put in a new dizzy at the same time :oops:
Triumph1300
No but maybe this'll help
#2 Post by Triumph1300 »
The terminals are numbered on the back of the switch
T 1 = brown white trace cable
t 2 = 2 number white cables (may be on common lucar
t 3 =white red trace cable
t 4 = nothing if you haven't got a radio!
Hope this helps!
BWJ
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
1300dolly
#3 Post by 1300dolly »
thanks bruce. the five wires were confusing me, i have no radio.
i will tryt that this weekend.
Inst function more important...
#4 Post by Jon Tilson »
Brown = live feed
White = ignition switched live out - should go to fuse box.
white/red = starter solenoid circuit - dont forget box loom connector.
Anything esle = radio non ignition but still switched feed.
Sure you all new that anyway....:-)
