In that distance it has had two head gaskets, one due to a heater hose fracture and the other to a cam change.
When the piston ring broke I decided to rebuild it as I had built it in the first instance, the lone damaged piston was replaced by one that Carl on here had sat in his garage
I was amazed to find that the crank journals were all standard and unworn
I was just about to buy all the bits to rebuild when I was dismayed to find that mains 2,3,&4 had a fracture running through the bolt holes
I have three blocks in the garage to choose from but will have to get it bored to suit my + 020" Mahle pistons.
