VYK The Russet 78 Sprint
Bish
Re: VYK The Russet 78 Sprint
#106 Post by Bish »
Back on the tarmac
I like it! It’s where I wanted it to be in terms of ride height. Time will tell how well it drives though.......
Interior next.
dollyman
TDC Cheshire Area Organiser
#107 Post by dollyman »
That looks very nice Bish :D The ride hight just nice, not to high or to low. :thumbsup:
Bish
#108 Post by Bish »
dollyman wrote: Sun Feb 23, 2020 4:24 pm That looks very nice Bish :D The ride hight just nice, not to high or to low. :thumbsup:
Thanks Tony. I’m chuffed with how VYK sits. Can’t wait to get cracking with the interior now. Then it’s a case of refitting both screens with new rubbers, new side stripes and a few finishing touches. MOT and get out on the road for a proper shakedown, probably have a new list of jobs to do after that! But, Im so close now - let’s hope there’s some sunny days around the corner. :thumbsup:
Awaiting Repair
#109 Post by Awaiting Repair »
It sits very well! It also looks fantastic in the 'period' Russet! Have you considered leaving as is and not fitting the stripes............. looks great without them!
Keith
Bish
#110 Post by Bish »
Awaiting Repair wrote: Sun Feb 23, 2020 8:22 pm It sits very well! It also looks fantastic in the 'period' Russet! Have you considered leaving as is and not fitting the stripes............. looks great without them!
Keith
Thanks Keith. I love the russet. Poo brown is the way forward!
Hmmmm - to stripe or not to stripe.............. :-k
Think I will though.
oily66
#111 Post by oily66 »
The sprint always looks that bit better sat lower, in my opinion it goes with the name.
Slightly more aggressive too.
You got it right there bish.
Trevor
2017 Jaguar XE R-sport
dollyman
#112 Post by dollyman »
Keith
Your Russet sat well Keith, in the end 8) Wait till we get the yellow peril going :thumbsup: :thumbsup:
Bish
#113 Post by Bish »
oily66 wrote: Sun Feb 23, 2020 9:25 pm The sprint always looks that bit better sat lower, in my opinion it goes with the name.
Thanks Trevor. Any pics of your magenta Sprint anywhere?
Forgot I took a front view photo too.
I will definitely put the stripes back on. I have a silver set from the club in stock. Any tips in how to apply them would be appreciated.
:thumbsup:
Awaiting Repair
#114 Post by Awaiting Repair »
Here's my Russet from a 1990 photo. Non standard stripes!
brown cropped.jpg (66.27 KiB) Viewed 5537 times
Reg
#115 Post by Reg »
Bish wrote: Tue Feb 25, 2020 8:49 pm I will definitely put the stripes back on. I have a silver set from the club in stock. Any tips in how to apply them would be appreciated.
:thumbsup:
Hi Bish, I used to do custom decals, stripes, flames ect for a couple of years for various car dealerships during the eighties.
The way I did it was...one panel at a time, gently stick one end of the stripe to one end/side of the panel, then seperate the backing paper to about two feet at a time, but do not cut at all yet, keep on the spool. Then pull the stripe enough to take up the slack, but not to much where you can easily stretch it, and get as close as you can to the panel and look down it as you apply. Very gently, tap the end of your finger to stick it to the panel, about a foots length at a time (to eliminate a saggy looking line)..then if you make a mistake it comes unstuck easily. Only when you are happy with it and have looked down the panel several times at every angle for any wavy places in your stripe, use a clean soft cloth, not your finger, to run down the stripe, gently at first though, otherwise it could catch and drag the decal. Then using a very sharp blade, (must be sharp to get a nice clean cut) cut the decal to the desired length.
Stand back and admire your handywork.. 8)
Reg.
Bish
#116 Post by Bish »
Awaiting Repair wrote: Tue Feb 25, 2020 9:41 pm Here's my Russet from a 1990 photo. Non standard stripes!
I like it. I will stick with the one stripe though as I want the car to be standard looking.
Bish
#117 Post by Bish »
Reg wrote: Wed Feb 26, 2020 9:34 am
:thumbsup:
Reg.
Wise words Reg, thanks for that! Patience has never been my strong point but I will bite my lip and give it a go. I wonder if the stripes supplied by the club are one piece per side? Stick it on and trim where the door shuts are, or in separate panel length pieces? I worry about getting the stripe straight! I think I have read somewhere that the stripes start about 1 3/4 inches from the leading edge of the front wing. Anyone know if that’s correct please?
Reg
#118 Post by Reg »
Hi Bish. The club stripe sets I have used, have always been in sections. So, nice and easy..one panel at a time.
As for the front wings, I allowed 1/2in to fold round the edge of the wing where the door hinges fit. Making sure to de-grease this area from the nastiness that could build up and lurk there over time.
Do the front wings first and the thinner stripe of the two is on top. I've seen quite a few cars over the years with the stripe the wrong way up! I think that particular mistake is easily made when one starts on the rear wing, get all the way to the front wing where it tapers, and at that point see the mistake, and uniformly say to themselves.."BO**OCKS"! :oops:
I can't tell from your pictures (lovely car and stance by the way) how good your panel alignment is, but please get this done as best as you can before the decals..once on, they will highlight any difference in panel heights!
Bish
#119 Post by Bish »
Reg wrote: Fri Feb 28, 2020 5:16 pm Hi Bish. The club stripe sets I have used, have always been in sections. So, nice and easy..one panel at a time.
Wise words again Reg thanks. I will give the car a good degrease first, plus the near side rear door could do with adjusting up before I attempt the stripes. How about height of the stripe. Do you just use the swage line in the panel as the guide?
Reg
#120 Post by Reg »
Yep, a couple of mm under the swage line..just as the panel flattens out. It's good that you will sort out the doors before the stripes..otherwise, if you adjust them after, the stripes will be misaligned..nightmare! :evil: Enjoy! 8)
