The resurrection of KSF404T - 1978 Sprint
triple tango
Re: The resurrection of KSF404T - 1978 Sprint
#106 Post by triple tango »
only that I have plenty of it :lol:
triple tango
#107 Post by triple tango »
another productive evening;
valve clearances all set, head torqued down.
oil system primed using a drill (in reverse!) untill oil comes out of the rearmost cam
something worrying I noticed, was that as the valves have been refaced smaller shims were obviously needed to restore valve clearances, but if shims less than 0.100" are used on the exhaust valves the shims are no longer proud of the recess in the spring retaining cap. Which means the edge of the rocker can press on the cap which is very risky, so I relieved the edges of the rockers slightly to make sure there is no chance of them touching the spring retaining cap. This is somthing to watch on any Sprint when valves are refaced.
Howard81
#108 Post by Howard81 »
Excellent work Roy 8) 8)
It makes me very glad that I didn't attempt to do this myself, there are so many things I wouldn't even know how to do.
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
triple tango
#109 Post by triple tango »
Sat morn is reserved for fitting your engine back in the car.....
Purplebargeken
#110 Post by Purplebargeken »
Paggy Blue Sprint for the L2B run then eh?
Howard81
#111 Post by Howard81 »
purplebargeken wrote:Paggy Blue Sprint for the L2B run then eh?
I hope so :mrgreen:
Purplebargeken
#112 Post by Purplebargeken »
Woohoo!
triple tango
#113 Post by triple tango »
finished at last, its ready to install now.
Had a few more problems on the way; I set valve clearances, torqued head down, then fitted cam sprocket - then found one of the threads had stripped in the cam :fuming: . So I drilled & tapped it to 5/16 unf in situ. To stop any swarf getting in engine I had the engine upside down & lots of grease on the drill. Then an inlet manifold bolt needed helicoiling. Also the little pipe that goes between the waterpump cover & manifold had been wound in insulating tape & hammered in place with lots of silicone! So I threw it away & found a spare in my shed.
It just needs the airbox painting now, thats Howards job !
Howard81
#114 Post by Howard81 »
Excellent work, the engine looks beautiful! At least I have one job to do - I'll get a can of grey paint on standby :lol:
I have the air hoses and bracket ready to go on, too :)
#115 Post by xvivalve »
Have you used that length of filter before Roy? I use a shorter one as I found the long ones either interfere with the rack/mount or are difficult to remove in-situ because of it...
triple tango
#116 Post by triple tango »
phew, now for breakfast,
Purplebargeken
#117 Post by Purplebargeken »
Cor, if you listen hard enough you can actually hear Howard chomping at the bit and shaking a rattle can of grey paint. Amazing!! :lol:
Belting job Mr. TC
Howard81
#118 Post by Howard81 »
rattle rattle rattle :lol:
Excellent work Roy, is she running yet? :D
triple tango
#119 Post by triple tango »
ahem,
Howard81
#120 Post by Howard81 »
:D :D :D :D :D :mrgreen:
BTW, the BRAKE light comes on whenever it feels like it, I think it's due to the wire on the handbrake warning switch coming off and floating about under the carpet somewhere. I'll get the carpet up one day and find it...
I am pretty sure that Triumph meant it to be a "Break" light. It comes on when the car is about to break... :roll:
