Page 9 of 16
Re: my track sprint project
Posted: Mon Feb 22, 2010 7:42 pm
by DF
Neil907 wrote:Cheers for the comments.
I did consider mounting it to the chassis but in the end decided that leaving them on the subframe will give me more room to fit the exhaust in, Which is probably less of an issue on an upright engine.
What's happened to the updates on your thread Darren, was enjoying seeing it come together.
Oh i see didnt think about your ex manifold.
I will eventually update my thread with whats been done,
Havn't felt like doing much to the car as my mother has passed away and its knocked the stuffing out of me.
If i can be bothered i hope to get back on it in the spring as i've lost all enthusiasm at the mo,
watching yours come together may spark me off again ,
Posted: Mon Feb 22, 2010 8:45 pm
by Neil907
Sorry to hear about your mother Darren.
I hope the enthusiasm returns soon.
Posted: Mon Feb 22, 2010 9:40 pm
by Purplebargeken
Darren, also very sorry to hear your news
I hope things will pick up for you soon enough. All the very best.
Ken
Posted: Tue Feb 23, 2010 9:09 pm
by DavePoth
+1 Darren. I lost my dad last year and it's absolutely horrible
, but when I was ready for it I found pushing on a bit with my car helped to keep my mind off things
Posted: Sun Apr 04, 2010 2:49 pm
by Neil907
Time for another update.
The new propshaft I have had made, single piece 3"dia with motorsoprt UJ's to fit sprint gearbox and atlas axle.
Fitted to the car to check for clearance and alignment.
I have cut the back piece out of the standard subframe and made it a bolt piece to aid changing the gearbox. hopefully I won't need to do that to often.
I picked up my lightweight panels from Rob at Sprintspeed on friday.
The plan will be to drill the frames out a bit more to save a bit more weight.
The rear arches are of the same style as the ones I allready have but 1" wider so will give the car a more even look compared to the fronts. They are also somewhat tougher than my others.
__________________
two turbos no cam
Neil
View Public Profile
Send a private message to Neil
Find More Posts by Neil
Add Neil to Your Buddy List
Posted: Sun Apr 04, 2010 5:41 pm
by DF
Neil where did you get your 4 link kit from
I have ad a look at a few and i didnt like the look of them,
The rear arches look good but how will you fit them to the wing ?
Im getting the enthusiasm back at long last,
Posted: Sun Apr 04, 2010 10:11 pm
by Neil907
The 4 link kit is from Gartrack, the chassis pickup box and axle brackets are mk2 escort, the rods were made to my measurments and the tunnels I made myself.
As for the arches, will probably rivet a 10mm lip then fill over the top or may jsut srew them on and not worry about looks to much.
Glad to hear you are getting the enthusiasm back Darren, it can be tough at times.
Posted: Sun Apr 04, 2010 10:12 pm
by DavePoth
That's going to look immense with those arches.
Posted: Sun Apr 04, 2010 11:25 pm
by DF
Cheers Neil
Dave,s right the arches look awesome.
Posted: Mon Apr 05, 2010 9:43 am
by topfuel
i need them arches!!!! when did you get them neil?
cheers terry
Posted: Mon Apr 05, 2010 11:24 am
by DoloWIGHTY
This car is already a legend before it's even touched the tarmac. Breath taking stuff.
Posted: Mon Apr 05, 2010 2:12 pm
by Neil907
topfuel wrote:i need them arches!!!! when did you get them neil?
cheers terry
Hi Terry
Igot them from Rob at Sprintspeed
http://sprintspeed.co.uk/
Cheers for all the good comments guys.
Posted: Fri May 07, 2010 5:25 am
by newguy
Neil How i have missed your updates.
Good to see you are still getting into it.
Question, What diff is that?
And what modifications did it require to fit?
Posted: Sat May 08, 2010 6:26 pm
by Neil907
Hi Stew
Its a Ford atlas axle from a Capri, In theory you would only have to have to weld the Sprint axle mounts to it and it would fit plus a different prop and some arches is its a fair bit wider. You can get a baby Atlas as fitted to non bubble escorts. For mine though I went with a 6 link suspension and turreted, which meant allot of work.
Posted: Sun May 09, 2010 10:24 pm
by newguy
Neil907 wrote:Hi Stew
What Year/Model Capri?
Cheers for the Info Neil Sorry to Hijack
