MX5 Dolly
Re: MX5 Dolly
#121 Post by Mad Mart »
Mx5 turbo dolly wrote:Any do a kit for a rear disc brake conversion?
You could ask Ken Clarke, I'm sure he's done it to several Sprints.
Mx5 turbo dolly
Re: MX5 Dolly
#122 Post by Mx5 turbo dolly »
Has anyone got his contact details?
Oli_88
Re: MX5 Dolly
#123 Post by Oli_88 »
Question;
What diff are you running? Open or Welded/LSD?
Hit it.
Re: MX5 Dolly
#124 Post by Mad Mart »
Mx5 turbo dolly
Re: MX5 Dolly
#125 Post by Mx5 turbo dolly »
Oli_88 wrote:Question;
Ive got a welded 4.1 diff in a sprint axle
Mx5 turbo dolly
Re: MX5 Dolly
#126 Post by Mx5 turbo dolly »
Will tr7 axle bolt straight on?
I'm not worried about the width.
Re: MX5 Dolly
#127 Post by Carledo »
Its not a direct bolt in, the upper arms have a different (better) location method and the lower arm mounts are a bit further apart,this may be get round-able just with the movement in the bushes, it's only about an inch per side. I think the overall track difference is in the region of 2.75" across the hub flanges (no doubt someone will be exact, I only measured it roughly against a Toledo 4.11 axle)
I have all 4 arms to go with that axle..........
Dolly-Nut
Re: MX5 Dolly
#128 Post by Dolly-Nut »
Did you or someone else weld it?
Mx5 turbo dolly
Re: MX5 Dolly
#129 Post by Mx5 turbo dolly »
Someone else!
I don't trust my welding that much!
Dolly-Nut
Re: MX5 Dolly
#130 Post by Dolly-Nut »
Oh I was interested as I might give one a go. How is it for everyday driving?
Re: MX5 Dolly
#131 Post by soe8m »
Dolly-Nut wrote:Oh I was interested as I might give one a go. How is it for everyday driving?
Everyweek changing halfshafts....
Mx5 turbo dolly
Re: MX5 Dolly
#132 Post by Mx5 turbo dolly »
The steering is quite heavy at parking speeds,
the inner wheel skips when Turning slowly.
But it is much more predictable when going
Sideways!!
I have not snapped any half shafts and I'm running
7" rear wheels.
I have got to change my wheel bearing seals
But they were shot before I welded the diff!!
An LSD would be better,just not at £700+!!
edz27
Re: MX5 Dolly
#133 Post by edz27 »
Any updates on this is this car still around, and any chance of some pics as the links have been removed, very interested in this conversion :D
Re: MX5 Dolly
#134 Post by Mad Mart »
Yep, it's still around. Should be at Castle Combe on 14th April.
Dolly-Nut
Re: MX5 Dolly
#135 Post by Dolly-Nut »
Mad Mart wrote:14th April.
:spliff:
