I have to say, the tears were from Roy, tears of joy as he was so happy to see shot of it... Thanks, Roy, you've done a great job with the engine! I promise to try not to break KSF again
Roy's sprint is absolutely stunning, it was great fun on the twisty roads to Peterborough trying to keep up with it
There is a slight running problem with it though, the rev counter jumps around like crazy when you accelerate (it can fluctuate up to 2000 RPM more than the actual RPM), and the acceleration is somewhat lumpy.
There WAS initially a fuel flow problem, but I blew through the fuel lines at the Eastern Dolly Day and it ran a lot better after that, no more haltering when trying to accelerate. Just lumpy acceleration.
However, at a constant cruising speed, the rev counter sits still and the car runs perfectly. If it was simply a fuel line block, the front carb would usually run out of fuel and the car would refuse to accelerate and slow down, but not in this case (it was beforehand though). The acceleration is there, the speed is there, it's just lumpy - not nice and smooth! I've tried a different rev counter, but it's exactly the same. The only other thing that has changed was the addition of the Luminiton Magnitronic ignition.
All I can think of is that the new Lucas DB105 sports coil is faulty, any ideas? Roy has wired it up properly, so I know it's not that.
Fuel tank is coming out (again) for a clean tomorrow!
