whats wrong with clutch??
DavePoth
#16 Post by DavePoth »
Sounds like your clutch isn't disengaging properly. It might be a hydraulic problem, or a bent clutch arm. That might explain why the wear on the clutch was so bad.
topfuel
#17 Post by topfuel »
think i may have found the problem with my clutch....
clutch itself is fine.
i think the whole crank is moving..i.e thrust washer are shot.
end float on the crank can be measured with a tape measure!! (1/8th of a inch)
cheers terry
Could be,...
#18 Post by Jon Tilson »
The 1500 engine prone to this...the 1300 not quite so...
You need to sort it pronto or irreperable damage to crank and bearing cap will result if it hasnt already.
