Handbrake warning light?
Ian Howard
Re: Handbrake warning light?
#16 Post by Ian Howard »
Since acquiring our Sprint, the H/B warning light doesn't extinguish (well it has on the odd occasion!) - I suppose it must be a 'sticky' switch, though it seems very difficult to acces to verify...(?)
Ian
Richard the old one
#17 Post by Richard the old one »
If your sprint has a tandem braking system I would start by disconnecting the cable that goes to the Pressure Differential Warning Actuator PDWA as I believe that on sprints like my 15OOHLs the brake warning light comes on to indicate either the handbrake is on or there may be a problem with the brake hydraulics. My experience is that the PDWA is more of a problem than it is worth. I believe the important thing is to check that there is not a hydraulic leak by checking the level of the brake hydraulic fluid regularly. If there is a leak from the master cylinder you will often see it leaking out below the master cylinder / servo junction.
Ian Howard
#18 Post by Ian Howard »
Thanks for that Richard - I shall check that out when I get back home (am away working for a while unfortunately).
Regards
Ian
