Re: Rolling Project - 1980 1500 HL Auto
Posted: Fri Jul 27, 2012 1:46 pm
Does the car have electronic ignition?
It didn't when I sold it, but I have a recollection that it had been fitted during the previous restoration.. I am wondering if the coil had been changed, as it had a ballasted sports coil (DLB110? it was silver with a red/white Lucas label) on when I sold it. It was the one that originally came off my Sprint after I converted that to electronic ignition.
If if hasn't been changed, then it really should be changed to a non-ballasted one.
If it has been changed, then worth checking all the same as there are a lot of cheap counterfeit Lucas DLB105 coils on the market that don't last long at all!! Also that the ballast wire has been bypassed - the coil will connect directly to the fusebox.
Of course it could have been changed, then converted back to points in which case check the wiring has been put back correctly.
