Maggie the Toledo - rattles or just character?
Dolly-Nut
Re: Maggie the Toledo - rattles or just character?
#16 Post by Dolly-Nut »
I've never had any trouble removing steering wheels :? It might be worth putting some WD40 or similar down the splines the night before removing though.
As for the rattle it's just a case of listening around for it and hitting things until it shuts up. You'll never get rid of them all! Just make the engine louder or turn up the radio! :wink:
#17 Post by Jon Tilson »
In a word no...
You need the special Churchill puller to get any Triumph hub off the shaft.
Messing about with any of the leggy types will just bend the hub flanges unless you are very lucky.
The Churchill type clamps to the flange and keeps it all square and will have it off in a jiffy...
Essexwriter
#18 Post by Essexwriter »
Took a closer look for the source of this dashboard/footwell rattle at idle. Still perplexed, but not intending to pull out the parcel shelf etc until the weekend. BUT I did discover the rattle dies down if I push the brake pedal. Anyone else experienced something like this in the past?
Re the steering, the lower bush looks fine so will investigate higher up the column first.
Cheers,
Ben
Dolly-Nut
#19 Post by Dolly-Nut »
Essexwriter wrote:Took a closer look for the source of this dashboard/footwell rattle at idle. Still perplexed, but not intending to pull out the parcel shelf etc until the weekend. BUT I did discover the rattle dies down if I push the brake pedal. Anyone else experienced something like this in the past?
Cheers,
Ben
Have a listen to the servo, mine rattles a bit at idle. It could also be the pivot pin the connects the pedal to the rod.
Essexwriter
#20 Post by Essexwriter »
Dolly-Nut wrote: Have a listen to the servo, mine rattles a bit at idle. It could also be the pivot pin the connects the pedal to the rod.
I think you may have cracked it. I've only had a quick inspection, but it does seem to be the most likely culprit - if I push the rubber seal from inside the footwell, it seems to die down a little. I don't fancy mucking about with it, though, so I think I'll just have to live with it for the time being.
Thanks for the help.
Cheers,
Ben
Essexwriter
#21 Post by Essexwriter »
Sorry for the idiot question, but how often do you recommend changing oil in the Toledo? I've just realised I've done about 2,500 miles since the beginning of December. Nearly time for a change?
(Totally off topic. Watching programme about the Tube, with talk about sulphur fumes in the tunnels. Does anyone else remember being told as a kid that Tarmac fumes were good for your lungs?)
#22 Post by Carledo »
I have a spare Toledo servo for sensible money if you're interested.
Dolly-Nut
#23 Post by Dolly-Nut »
Essexwriter wrote:Sorry for the idiot question, but how often do you recommend changing oil in the Toledo? I've just realised I've done about 2,500 miles since the beginning of December. Nearly time for a change?
I'd go every 4k with a decent oil and anti-drain filter but a lot of people change at 3k and some even under that.
captain_70s
#24 Post by captain_70s »
For an incentive to change you oil regularly check out what happens when you don't... :lol:
speedyxjs
#25 Post by speedyxjs »
captain_70s wrote:For an incentive to change you oil regularly check out what happens when you don't... :lol:
Ouch!
Essexwriter
#26 Post by Essexwriter »
Yes, that picture's convinced me. Oil change coming up *very* soon!
Steve - I'll check for certain this weekend that the rattle is coming from the servo. If it is, I'll drop you a PM. Thanks for the offer.
Cheers,
Ben
neil brown
#27 Post by neil brown »
If your indicators are cancelling in the wrong place turning the steering wheel will not help.
At some time someone has relaced one of the lower column joints and not lined everything up again, difficult job as the retaining bolts for the flexible coupling are at 90 degrees to each other which means the steering has to be turned to undo them.
If you remove the bolts from the flexible coupling, reset the wheels to straight, slide the coupling up the shaft (usualy easier said than done), turn the steering wheel staight then refit the coupling and bolts everything should line up, usually at the 3rd or 4th attempt!
triumphtoledo
TDC Toledo Registrar
#28 Post by triumphtoledo »
Some of my Toledos have rattled from the servo; it is the non-return valve that is faulty, which is the white plastic thing that the hose goes to, from the inlet manifold. No need for a replacement servo.
R
Essexwriter
#29 Post by Essexwriter »
neil brown wrote:If your indicators are cancelling in the wrong place turning the steering wheel will not help.
Difficult job? I might pass that one on to a professional :D
Thanks for the advice. Appreciated.
Essexwriter
#30 Post by Essexwriter »
triumphtoledo wrote:Some of my Toledos have rattled from the servo; it is the non-return valve that is faulty, which is the white plastic thing that the hose goes to, from the inlet manifold. No need for a replacement servo.
R
Thanks for that. Is it worth taking the valve off and giving it a clean up before trying a replacement?
I tried giving the valve a twist to see if that would make a difference, but it didn't - wishful thinking on my part.
