Alternative Wheels
Re: Alternative Wheels
I made sure that my wheels came with the nuts and centre cap when I bought them. I dug out the mgf logo and stuck some triumph ones in for a bit of detail.
Yes, sorry.
At the top of this thread, I made mention of nuts, the ones I used came from ebay labelled for mkI Escort (7/16 UNF) and have a fat, tapered shoulder at the wheel fitting point to take care of the overlarge holes in the F rim. They've been on mine for 5 years now with no problems except the chrome is now getting a bit manky in spite of me NEVER using an airgun on them! £24 for 16 IIRC.
I just painted out the MG logo on my front wheel centre caps, the rear wheel caps won't fit over Sprint hub nuts anyway so I just sprayed the drums and nuts with wheel silver to make it less obvious.
A few days ago, I came across the following advertisement for 4 x 3¾ inch (i.e. 4 x 95•25 mm)
PCD Cosmic alloy wheels, of the same style as were originally fitted to my 1974 Triumph Toledo, when my father bought it in May 1975:
http://www.ebay.co.uk/itm/alloy-wheels- ... 2407811211
alloy wheels cosmic - 4 x 95.25 - 13 inch alloys
4 x 95.25 COSMIC genuine alloys. Need a refurb. 2 of these rims are 5.5J and 2 are 6J
13 inch diameter rims
Offset on the 6 inch rims:- +20mm
Offset on the 5.5s = +25mm
The 13 x 5½ inch wheels listed here, seem to be of slightly different offset to mine, which I had measured as 21 mm.
Regards.
Nigel A. Skeet
Nigel A. Skeet
- gmsclassics
Dan
Can't help with the wheels themselves, but a few other tips that might be helpful based on what I've had to use on the car I race.
195.60x14 tyres are the largest I believe you can fit under the rear wheel arches, and it is definitely the rears that are limiting. You could possibly use other tyre / wheel combinations that match the rolling circumference / width of these. I went to 195 as it simply allows faster cornering and better braking than with 185.
I'm not allowed to fit arches and had to do a lot to avoid rubbing:
1. roll the outer bodywork lip flat to the panel.
2. fit long M12 wheel studs (I found ones that will press in the existing holes) so that you can fit spacers to help centralise the wheels and perhaps overcome some issues with wheel offset
The next issue is roll and lateral forces on cornering, so both stronger rear springs and bushes on the rear tie bars. In fact one of my tie bars is adjustable to ensure the axle can be centralised. I have to replace those bushes regularly (same on the fronts). My rear springs are 200/250 lb variable, lowered one inch body to axle. Fronts are 500 lb but that combination isn't very comfortable on the road!
Because of corner roll, any rubbing is most likely on the inner wing and it shows up easily if you spray that with a light coat of grey primer.
If you want to then further improve handling, beef up the front sway bar and remove the rear, especially without an LSD as it will go some small way to avoid lost power due to one rear wheel lifting causing wheel spin exiting corners.
Geoff
Geoff
If I were to acquire MG F or MG TF 15 x 6 inch wheels, it was not my intention to retain 205/ 50 R15 tyres on the rear and 185/55 R15 tyres on the front. If all four wheels had been fitted with 185/55 R15 tyres, in common with the MG Maestro & Montego, I might have retained this tyre size, until I eventually substituted 185/65 R15 tyres all around, including a spare.Carledo wrote:I very much doubt you will be able to persuade the F rims into the rear arches of your Toledo without some rubbing of the sidewall, even at standard ride height. I initially ran 205/50/15 tyres on the rear (they came with the wheels) which came into contact with the (unmodified) arches frequently, particularly during spirited cornering. At this point in time the suspension was entirely stock and pretty worn in the bush department.
During its evolution, the car gained antiroll bars at both ends, ASP Gaz shox and polybushes which stiffened, lowered and generally tightened up the ride. I also got some slightly narrower 195/50/15 tyres. All this conspired together to reduce roll and improve axle location to the point where I was only getting occasional sidewall scrubbing at "full lean" and on very big bumps.
Did you ever consider trying the car with the 205/50 R15 tyres on the front and the 185/55 R15 tyres on the rear!?! It might have resulted in decreased understeer or increased oversteer, but it also might have quickly given a baseline for comparison, regarding suitable tyres for the rear wheels.
So, given that the front & rear wheels are fitted with tyres of different sizes and aspect ratios, what do you carry as a spare; possibly an MGF 14 inch space-saver steel wheel and 175/65 R14 tyre or a Triumph Toledo original 13 x 4½ inch steel wheel & 155 R13 tyre!?! These days, I seem to see so many cars, whose wheels are fitted with ultra-low-profile tyres, having to use the space-saver spare, with its yellow, 50 mph maximum speed limit sticker.
185/55 R15 – 1836•2 mm circumference
155 R13 => 155/82 R13 – 1835•9 mm circumference
175/65 R14 – 1831•8 mm circumference (0•24% smaller than 185/55 R15)
205/50 R15 – 1840•9 mm circumference (0•26% larger than 185/55 R15)
155 R13 => 155/83 R13 – 1845•6 mm circumference
195/50 R15 – 1809•5 mm circumference (1•45% smaller than 185/55 R15)
155 R13 => 155/80 R13 – 1816•4 mm circumference
After fitting the low-profile, Firestone S211, 185/70 SR13 tyres in July 1987, all of my driving had been on relatively straight roads, with a lack of significantly “high-speed” bends; whilst I worked at Celcon, in Grays, Essex, and later at Fulmer Yarsley, in Redhill, Surrey.
It wasn’t until after the Easter 1991 university-vacation, whist studying at RMCS on the Oxfordshire & Wiltshire border (a weekend return journey of nearly 130 miles each way, to and from Canvey Island, Essex), that the Toledo first exhibited disconcerting steering characteristics, when negotiating tight bends under power, which resulted in a sudden transition from understeer to oversteer in the blink of an eye. On the first few occasions that this occurred, it was quite frightening!
This later led me to wonder, whether the Cosmic wheels’ lesser offset (offset = circa 21 mm) in combination with the ‘original’ 175 SR13 tyres’ circa 5•5% larger rolling-radius, might have wholly or partially cancelled each other’s effects on steering-offset (aka scrub-radius), to retain similar steering characteristics, to what would probably have been the norm, with the original factory-fitted wheels!?! Having never driven the car, with the original factory-fitted 4½ x 13 inch steel wheels (offset = circa 35 mm?) and 155 SR13 tyres, I could only speculate.
This phenomenon was not eliminated until July 1996, when I took the opportunity to substitute a set of five Triumph Dolomite Sprint wheels (offset = circa 35 mm); retaining my Firestone S211, 185/70 SR13 tyres.
This experience has made me somewhat wary of changing wheel-offset and/or tyre external radius (directly proportional to both diameter & circumference), in case these disconcerting steering characteristics return. This leads me to think that substituting the Triumph Dolomite 1500’s rear-axle ratio of 3•89:1, in place of the Triumph Toledo 1300’s rear-axle ratio of 4•11:1, might be preferable to substituting larger wheels & low-profile tyres, as a way of improving fuel economy.
Given that 185/55 R15 and 155 R13 (or 155/82 R13) tyres have virtually identical rolling radii, the difference in wheel-offset will result in a corresponding change in steering-offset, which might induce similar effects to those I experienced!
I understand that ride height would be reduced by substituting tyres of smaller rolling (i.e. external) radius and/or shorter suspension springs having the same stiffness constant, but I cannot visualise how anti-roll bars, polyurethane bushes or gas dampers would affect the ride height!?!
I retro-fitted Dolomite Sprint front & rear anti-roll bars in 1982 and also de-cambered the front wheels by removing the spacer shims between the upper section of the front-wishbone brackets and the front sub-frame. These radically improved the road holding. If I need to replace the suspension & steering bushes, I might substitute polyurethane bushes, but being significantly more expensive than rubber, I hope they last a lot longer!?!
I didn’t just carry rear-seat passengers. On a few occasions, I carried several heavy 1½ feet square concrete paving slabs, for which the Toledo’s boot configuration was well suited, but the car was riding low on its suspension. The VW Type 1 Beetle style air-cooled engine I carried in the boot, wasn’t quite so heavy. I would NOT wish to try lifting either the paving slabs or the engine in or out of a Dolomite’s boot, over that high boot-sill! I wouldn’t want to reduce the usefulness of the car as a load & passenger carrier, merely to go faster around corners! This is why I also prefer a four-door car to a two-door car, despite greater weight and reduced torsional stiffness.Carledo wrote:I don't have a rear seat so heavy weights in the back is not a problem.
195/50 R15 – 1809•5 mm circumference (288•0 mm radius)Carledo wrote:However, I was still not satisfied with the stance and the rubbing, so, when the opportunity arose, I relieved the rear arch lips which has stopped the rubbing and allowed me to lower the rear end another 20 mm making it "look" right and work better.
205/50 R15 – 1840•9 mm circumference (293•0 mm radius)
185/55 R15 – 1836•2 mm circumference (292•2 mm radius)
155 R13 => 155/80 R13 – 1816•4 mm circumference (289•1 mm radius)
155 R13 => 155/82 R13 – 1835•9 mm circumference (292•2 mm radius)
155 R13 => 155/83 R13 – 1845•6 mm circumference (293•7 mm radius)
175 R13 => 175/80 R13 – 1917•0 mm circumference (305•1 mm radius)
175 R13 => 175/82 R13 – 1939•0 mm circumference (308•6 mm radius)
175 R13 => 175/83 R13 – 1950•0 mm circumference (310•3 mm radius)
185/65 R15 – 1952•5 mm circumference (310•7 mm radius)
195/55 R16 – 1950•6 mm circumference (310•4 mm radius)
From my perspective, the ride-height is quite low enough, even with tyres (175 R13 or 185/65 R15 or 195/55 R16) whose external radius is approximately 5•5~7•5% larger than the factory-standard 155 R13 tyres (80~83% aspect ratio); implying a 17~21½ mm increase in ride-height and 17~21½ mm reduction in clearance between the upper tread of the tyre and the horizontal portion of the wheel arch.
By the way, does anyone have an accurate external-circumference measurement of various brands of new, unused 155 R13 tyres or used 155 R13 tyres with tread-depth measurement, which would help to clarify the aspect ratios (i.e. one or more of 80%, 82% or 83%) of standard-profile tyres?
It had already occurred to me that it might be a good idea to grind back the return-lip of my Toledo’s rear wheel-arches by about 10 mm, so that they were similar to the front wheel-arches, and provide more tyre-sidewall clearance.
I might also do the same with the 1973 VW Type 2 campervan, if and when I get around to substituting Mercedes C-Class or E-Class 7 x 16 inch alloy wheels (38 mm, 37 mm or 33 mm wheel-offset), with either 205/65 R16C or 215/65 R16C commercial-van tyres, in place of the original factory-fitted 5½ x 14 inch steel wheels (39 mm wheel-offset), with 185 R14 Reinforced tyres; for which I should be able to re-use the original wheel-nuts.
That might explain why the student who approached me, when I was teaching at Basildon College during 1995~96, was so keen to swop a set of five Dolomite Sprint wheels (circa 35 mm offset) for my set of five Cosmic wheels (circa 21 mm offset). He and his brother, whose family owned a garage workshop, had a project Triumph Spitfire, on which they said the Dolomite Sprint wheels wouldn’t fit.Carledo wrote:The stock Spitfire offset is something like 19 mm on a 4.5 or 5" rim.
When researching the availability of second-hand MG Maestro & MG Montego 15 inch alloy wheels, I came across the following advertisement, which suggests that they are of 28 mm offset:Carledo wrote:AFAIK the Maestro/Montego rims run an even bigger offset which make them suitable for the FWD Triumph range.
« A used MG Montego Maestro alloy wheel (6Jx15CH28) complete with centre cap and Goodyear Eagle Touring 185 55R15 81V NCT3 tyre with approx 7mm of tread. »
http://www.for-sale.co.uk/mg-maestro-alloy
According to the following website links, the various MG Maestro alloy wheels are of 25 mm or 28 mm offset, dependent upon wheel size. The 6 x 15 inch wheels, are said to be of 28 mm offset, which is exactly half-way between the offsets of the Dolomite Sprint GKN 5½ x 15 inch and Cosmic 5½ x 15 inch wheels [i.e. (21 + 35) / 2 = 28 mm].
http://www.wheel-size.com/size/mg/maestro/
http://www.wheel-size.com/size/mg/maestro/1983/
http://www.wheel-size.com/size/mg/maestro/1984/
http://www.wheel-size.com/size/mg/maestro/1985/
http://www.wheel-size.com/size/mg/maestro/1986/
http://www.wheel-size.com/size/mg/maestro/1987/
http://www.wheel-size.com/size/mg/maestro/1988/
http://www.wheel-size.com/size/mg/maestro/1989/
http://www.wheel-size.com/size/mg/maestro/1990/
If the same website is to be believed, the 6 x 15 inch wheels used on the 1995~2002 MGF and 2002~2012 MGTF cars, are also of 28 mm offset, but I would feel more confident if I could see that the wheels were actually embossed with their offset values, and the ultimate reassurance would be to actually measure it.
http://www.wheel-size.com/size/mg/F/
http://www.wheel-size.com/size/mg/F/1995/
http://www.wheel-size.com/size/mg/F/1996/
http://www.wheel-size.com/size/mg/F/1997/
http://www.wheel-size.com/size/mg/F/1998/
http://www.wheel-size.com/size/mg/F/1999/
http://www.wheel-size.com/size/mg/F/2000/
http://www.wheel-size.com/size/mg/F/2001/
http://www.wheel-size.com/size/mg/F/2002/
http://www.wheel-size.com/size/mg/tf/
http://www.wheel-size.com/size/mg/tf/2002/
http://www.wheel-size.com/size/mg/tf/2003/
http://www.wheel-size.com/size/mg/tf/2004/
http://www.wheel-size.com/size/mg/tf/2005/
http://www.wheel-size.com/size/mg/tf/2006/
http://www.wheel-size.com/size/mg/tf/2007/
http://www.wheel-size.com/size/mg/tf/2008/
http://www.wheel-size.com/size/mg/tf/2009/
http://www.wheel-size.com/size/mg/tf/2010/
http://www.wheel-size.com/size/mg/tf/2011/
http://www.wheel-size.com/size/mg/tf/2012/
However, I have also come across two websites, which suggest that 2002~2013 MG TF wheels have a 45 mm offset and a 100 mm PCD. The latter also refers to 5½ x 15 inch and 6 x 16 inch wheels, but also has tabulated wheel and tyre sizes, with one example of a 15 inch tyre supposedly being fitted to a 16 inch wheel!?! Such extreme disparities between different information sources, does not inspire confidence!
http://www.tire-size.net/size/mg/tf/
http://cararac.com/wheel_sizes/mg/tf.html
I was under the impression that the unitary-frame body of the four-door Triumph Toledo and Triumph Dolomite range, were virtually identical, apart the extra six inches at the rear of the Dolomite, with its shallow boot lid, associated boot-sill and horizontal rear-light cluster. Hence, I surmised that the rear wheel arches were identical!Carledo wrote:I have not measured the offset, being a pragmatic engineer at best, I used the "suck it and see" method. But I reckon the offset MUST be around 33mm, bearing in mind the wheel is 1/2" wider than the Sprint wheel where the offset (as you have correctly stated) is definitely 35mm. This is why you were getting fouling of the rear arches with the Cosmics, the offset for the small chassis cars, Herald, Spit, et al, is NOT the same as the Dolomite range, as anyone who has tried to fit Sprint rims to a Spitfire will tell you!
Until I can be reasonably certain of the offsets of the various wheels, I cannot confidently proceed further and would be unwilling to pay for six second-hand wheels and tyres (four & one spare + one spare-spare) plus shipping, if they might prove to be unsuitable.
If the wheels are not stamped with their offset in mm (typically marked ET followed by a number), there is a simple way of measuring it using a cm & mm rule or tape measure, whose calibrations start exactly at the end (i.e. no space between end of rule or tape measure and the start of measurement section). This can still be done successfully to reasonable accuracy with the tyre still on.
1) Place the wheel flat on a level floor or table surface, with the outer section of the wheel (the part where one would fasten the wheel-bolts or nuts) facing upwards;
2) Measure vertically upward from the level surface to the wheel’s mounting face (the part which makes contact with the car’s wheel-hub);
3) Turn the wheel over so that the outer section of the wheel (the part where one would fasten the wheel-bolts or nuts) is facing downwards;
4) Again measure vertically upward from the level surface to the wheel’s mounting face (the part which makes contact with the car’s wheel-hub);
5) Subtract the second measurement from the first and divide the answer by 2. This final positive or negative number, is the wheel’s offset in mm.
I too have used the “suck it and see” method in the past, but only as a last resort, when a better method wasn’t readily available to me.
This was the method I used in 1990 (pre Internet & on-line forum era), when I was possibly the first person in the World, to adapt the unusual cross-over-arm, pantograph rear window wiper system, that was factory-standard equipment, on the early-1980s vintage Vauxhall Astra Mk.1 estate car (aka Opel Kadett D Kombi), for use on the wide, shallow rear window of a 1968~79 VW Type 2 Transporter.
Nigel Skeet, “A Clean Sweep”, Workshop, VW Motoring, Warner’s Publishing Group, December 1996, Pages 85~86.
http://i275.photobucket.com/albums/jj28 ... 96-p87.jpg
http://i275.photobucket.com/albums/jj28 ... 96-p88.jpg
http://i275.photobucket.com/albums/jj28 ... -Ghost.jpg
http://i275.photobucket.com/albums/jj28 ... iper-1.jpg
By some miracle, it was almost ideally suited to its new application, although I later discovered that it could have been improved upon slightly, by using a similar system from an earlier Vauxhall Chevette estate car, which had a 55 mm longer wiper-arm and reduced sweep-angle to match! Fortunately for me, my speculative purchase only cost £10 and I didn’t spend any additional money until I was sure it would work.
I shall probably have to adopt the same approach, to finding a suitable rear-window wiper & washer system for my Triumph Toledo, which I assure you it does NEED, under certain driving & weather conditions.
I have ALWAYS been interested in fuel economy (re overall running costs & maximum range on a single tank-full), which for a given car and engine specification, appears to be influenced by both tyre rolling resistance (related to aspect ratio) and overall engine gearing (combination of gear ratio, final-drive ratio and tyre rolling-circumference), which is typically expressed in terms of MPH per 1000 engine-RPM. A potentially useful guide to initial choice of overall engine gearing is the brake specific fuel consumption contour chart for the engine, if available.Carledo wrote:TBH, I have no opinion and little interest in the effect of aspect ratio on fuel economy, since I am more interested in road-holding and performance. But I can tell you that my 2 litre, fuel injected, Vauxhall powered car averages around 36 mpg in its normal rural driving cycle. Contrary to popular opinion, I do NOT go everywhere flat out, but it does get "used".
It’s interesting to note that from the early 1990s onward, many cars for which fuel economy was highlighted as part of their desirable characteristics, were factory-fitted with 65-Series tyres, of which the Austin-Rover Montego 2•0 litre turbo-diesel was a case in point. For cross-country driving, these were said to typically achieve 50~60 mpg.
Given that MG TFs are available with 6 x 15 inch wheels plus 185/55 R15 & 205/50 R15 tyres, or 7 x 16 inch wheels plus 195/45 R16 & 215/40 R16 tyres, on front & rear wheels respectively, why did you choose to use at the rear, 6 x 15 inch wheels & 195/50 R15 tyres, rather than 7 x 16 inch wheels & 195/45 R16 tyres for example, whose wider rim with the same tyre-section-width would have resulted in the sidewalls having greater lateral stiffness? One could potentially use 195/45 R16 tyres on both the front and rear.
185/55 R15 – 1836•2 mm circumference (292•2 mm radius) – MG F & MG TF front
205/50 R15 – 1840•9 mm circumference (293•0 mm radius) – MG F & MG TF rear
195/50 R15 – 1809•5 mm circumference (288•0 mm radius) – Carledo rear
195/45 R16 – 1828•0 mm circumference (290•9 mm radius) – MG TF front
215/40 R16 – 1817•0 mm circumference (289•2 mm radius) – MG TF rear
Regards.
Nigel A. Skeet
Nigel A. Skeet
There are several reasons for this, firstly I was not sure the TF rims would fit (that 4x100 possibility) secondly, i'm certain a 7" rim would not go in the arch and thirdly (and most importantly) COST! The MGF 5 spokes I currently run for road work cost me £65 for 4 and none of the 3 sets I currently have (2xF sets and a set of 15" fake Minilites) cost me more than £100 a set - with tyres! The same financial considerations are behind the tyre choice of 195/50/15s, early in the cars life, I was offered a pair of Yokohamas in this size, almost new and £20 the pair! It would have been rude not to! Finding that they suited the car well, I have stuck with that size. The original pair of Yokos are now almost slicks and adorn my dry weather race wheels. But even the Toyo Proxes that I am currently using come to me fitted and balanced for less than £50 a corner, which I think is good value!naskeet wrote:
Simple really! It never occurred to me to put the wider wheels on the front as this goes against everything i've ever learned about RWD handling!
So, given that the front & rear wheels are fitted with tyres of different sizes and aspect ratios, what do you carry as a spare?
Again simple, I don't carry one! Just a tin of Finilec! Partly to save weight, partly to avoid this conflict in sizes, but mainly because the spare wheel well is full of battery, fuel pump and the large HP fuel filter the injection system needs!
Since offset is really the only important thing altered here one has to assume it is responsible. I can't see it myself, but to ignore it would deny Occams Razor.
I would go for the taller diff anyway, its much easier to do than faffing around with wheel/tyre sizes and it's effect can be easily calculated.
I use 185/55/15s on the front with the F rims and have none of those symptoms. Though when the 185s are worn out, I intend to standardize with the rears at 195/50.
The gas shox I used are of the adjustable spring platform variety which allow me to alter the ride height at will. This was an expensive choice forced on me by the total lack of information (even in the factory shop manual) on standard spring rates and lengths for the Toledo. I simply had no baseline to work from! Also with the different drivetrain and weight distribution, the car wasn't going to behave the same anyway and the ASP shox gave me an easy way out, albeit at £100 a corner!
I have other larger cars for load carrying, towing etc. Only on race days do I carry much weight about with spare wheels, tools and so on. And that all comes out before I hit the track!
If you like it that way, thats fine! Its not so much the rear ride height on the Toledo that looks wrong, it's the front! Stock Toledos habitually look as if someone has nicked the engine when you weren't looking!
Fit Sprint wheels to a Spitfire and, not only does it look all wrong with the wheels too far inside the body line, the front rims grind on the upper wishbone ends at anything approaching full lock. Spacers can cure this of course, but I hate the things and consider them dangerous.
When researching the availability of second-hand MG Maestro & MG Montego 15 inch alloy wheels, I came across the following advertisement, which suggests that they are of 28 mm offsetCarledo wrote:AFAIK the Maestro/Montego rims run an even bigger offset which make them suitable for the FWD Triumph range.
MY bad about the Maestro offset! I've discounted the Maestro wheels for my own use for purely aesthetic reasons, I don't like the flat outer face and cross spoke pattern that most of them carry! But my thinking here was influenced by the fact that Bruce Jones runs a similar set on his Triumph 1300 FWD. These may, on reflection, be Metro wheels rather than Maestro.
I have also heard that later Fs and TFs have the 4x100 PCD, but I have not physically checked this, just haven't bought any in case it's true! I know the Rover 25/45 wheels have 4x100 because I tried a set.
I have a spare set of early F rims, I will check them to see if the ET is shown and if not, try to get a measurement for you.
The Dolomite APPEARS to have a wider arch at the rear with a visible flare the Toledo does not possess. Perusal of the relevant parts lists however, shows that the INNER arch panel for both cars is the same part number. This leads me to the conclusion that the arches are indeed identical and the apparent extra width on the Dolomite is an optical illusion!
Fair comment!
Edit, I haven't done this very well! I have answered lots of questions in the quoted section but you have to read it carefully to work it out! Put it down to my lousy computer skills!
