Sprint Engine Rebuild
Re: Sprint Engine Rebuild
#16 Post by xvivalve »
Three hours!!!
Is that a +10 rebore by honing then? :lol:
shaunroche
#17 Post by shaunroche »
Wow, what good timing this is!
I have this very day bought a running sprint engine to rebuild with a view to building a track car: I haven't got anything else yet...just an engine!
So, I'll be keeping an eye on this build for sure!
How are you getting on with this now, still progressing?
matt of the vivas
#18 Post by matt of the vivas »
That needs a rebore. You wont ever remove those marks by honing alone, you will be wasting your time and wearing out your hone trying..
Matt.
shaunroche
#19 Post by shaunroche »
I assume then that honing doesn't remove as much material as a re bore then?
dursley92
#20 Post by dursley92 »
For me that needs a re-bore or maybe just a liner in the damaged one if the rest are good..
Russ Cooper
Dursley
UK
#21 Post by Mad Mart »
shaunroche wrote:I assume then that honing doesn't remove as much material as a re bore then?
The Honing tool is really just for deglazing the bores so that new rings can bed in properly. I usually only spend about 10-15 mins. deglazing (per cylinder).
Thanks for the feedback guys. You're probably right about getting it rebored/resleeved but I'm in no hurry so I may just wear out my honing tool trying. I'd better check the bore diameter as well. It's probably eliptical by now. :lol:
shaunroche
#22 Post by shaunroche »
Ah I see! Only ever built new engines so reconditioning techniques are all a bit of a mystery to me at the moment!
