Fitting B-Post trims...
grifterkid
Re: Fitting B-Post trims...
#16 Post by grifterkid »
Lovely stuff, thanks for that... :wink:
grifterkid
#17 Post by grifterkid »
Well, I've got my 'trims' and I am looking forward to fitting them at some juncture...
However, I know there are L/H and R/H one but the tops of the ones I have almost look like they have too much of a profile to them...!!! I have a feeling they should be 'straighter' at the top but I could be wrong!!!
Anyone?!?!?!
#18 Post by MIG Wielder »
I had a look at the ones on my 1850 and compared the angles with my tri-square. And yes you are quite right; there is an angle at both the top and a less pronounced one at the folded base end. Here are some photos. The top; the bottom and a diagonal side view showing how mine fit in the B-post itself. You can see a small gap at the base so mine are not fitted 100% perfectly.
HTH,
