Terminally Rotten Sprint - what to save?
mikeybish
Re: Terminally Rotten Sprint - what to save?
#16 Post by mikeybish »
shaunroche wrote:Hi Mikey, would you have the brkt that fastens the exhaust down pipes to the gearbox please?
That's probably the most desperate thing I'm after right now!
Cheers, Shaun.
Ps...and a tunnel mounted (horizontal) heat shield please! :)
Hi Shaun, heat shield was saved but provisionally promised to someone else (awaiting confirmation if they already have acquired one),
Will have to take a look for the bracket. I don't recall seeing it (the complete exhaust had rotted into non existence including 75% of the downpipe and the gearbox is sitting squarely on the garage floor with no obstructions, so don't hold your breath....
http://triumphandadversity.blogspot.com
http://mikeyb.weebly.com/
Essex Based Serial Triumph Offender!
"Mikeyb" on Club Triumph & TR Register Forums
shaunroche
#17 Post by shaunroche »
Does that mean you're keeping the exhaust brkt then?
#18 Post by xvivalve »
It's the bakelite internals of the servo that are obsolete; don't junk it just because the case is rotten as there are many non functioning servos with pristine cases...
mikeybish
#19 Post by mikeybish »
shaunroche wrote:Does that mean you're keeping the exhaust brkt then?
I didn't specifically mean that Shaun, just that I had never noticed one! However, now that I've looked, seen it and realised the complexity of it, I plan to leave it attached to the box for now. I do have a couple more boxes sitting in sheds, lockups etc. so if there are any spare on them I would be prepared to let one go - I'll let you know!
mikeybish
#20 Post by mikeybish »
xvivalve wrote:It's the bakelite internals of the servo that are obsolete; don't junk it just because the case is rotten as there are many non functioning servos with pristine cases...
servo now recovered, labelled and stashed "just in case"
shaunroche
#21 Post by shaunroche »
Mikey, I apologise....I clearly didn't see your response - if my reply came across as arsey then it wasn't intended...far from it!
Cheers for looking and getting back anyway! :)
mikeybish
#22 Post by mikeybish »
No worries mate, no offence taken :-)
mikeybish
#23 Post by mikeybish »
last call for free passenger side rear wing repair sections - see above - the trailer full of metal is off for disposal tomorrow and the wing will be on top of it :-)
