Page 2 of 2
Re: Recommended Sprint front brake upgrade.
Posted: Mon Mar 07, 2016 6:57 am
by tony g
Interesting to see the sprintparts au fit their caliper to the front too , like I did :)
What caliper is used Rob?
Posted: Mon Mar 07, 2016 10:39 am
by xvivalve
Carledo had some adaptors made up...
But there is another option that fits under a Sprint alloy, Ken Clarke has replicated the ST vented disc set up which uses standard but spaced calipers and longer (GT6?) stub axles...
Posted: Mon Mar 07, 2016 10:42 am
by Sundowner
tony g wrote:Interesting to see the sprintparts au fit their caliper to the front too , like I did :)
I've no idea, Tony, sorry. :oops:
But knowing the reputation these guys (Sprintparts) have, I reckon it'd be a decent one.
Rob
Okay.......
Posted: Mon Mar 07, 2016 11:37 am
by sprint95m
Maidstonerob wrote:Is there an adaptor for the Dolomite brake pipe union and the Sierra caliper
Most use a copper pipe, but that is not for me, so instead I did the following:
viewtopic.php?f=4&t=12257
(I don't know where the photo went but the description is concise?).
With this arrangement you don't have relocate the hose brackets and furthermore you can lift the caliper off
(to change the pads) without having to disturb the hydraulics.
The calipers fit easily under 1850 steel wheels or the Minator minilite replicas sold by Rimmer Brothers
but are very tight under Sprint alloys, usually making it necessary to grind a little from the caliper for clearance.
Calipers are common to the Sierras, Escorts, Orions, KAs etc that have 240mm vented brake discs.
For Dolomites with single line brakes there is no need to change the brake master cylinder.
Posted: Mon Mar 07, 2016 8:58 pm
by sprintchris
Thank you everyone for the info and advice, I shall contact the chap that makes these conversions.
