the grey wire is from the rev counter. One wire on the - side should go direct to the distributor. The red and white or cream wire comes from the starter and is the ballast bypass feed...12v when cranking.
The other wire is form the switch and should be ballasted voltage...6V
Hurah, engine starts, BUT...
Wires...
