Radiator
new to this
Re: Radiator
#16 Post by new to this »
SprintMWU773V wrote: Thu Jul 20, 2017 11:37 am As a slight aside I did recently purchase an aluminium one from Alicool complete with mounted fan and switch. I had it painted satin black, it looks very nice. The owner of the company personally hand delivered it to me as I work locally to him. Lovely quality item and significantly cheaper than the competition.
i had thought about the alli rad,nice bit of bling :D
But to dear
new to this
Re: Radiator
#17 Post by new to this »
cleverusername wrote: Wed Jul 19, 2017 11:16 pm
new to this wrote: Wed Jul 19, 2017 5:51 pm Thanks Guys
mine is leaking at the bottom,did put a cheeky bit on an alli one from ebay,but no joy :P,before i get mine rebuilt,i know some people have fitted a rad from Saab 9-3,what is involved in fitting,do you have to start cutting the car about to fit it ?
thanks Dave
Something I will be doing in a bit when I do my engine swap, someone had a Saab radiator from an old kit car for a tenner. Which compared to the price of Sprint one seemed like a bargain.
How straight forward it is, is something I will find out in a couple of weeks.
ive now got hold of a Saab rad,one thing i dont know is on the sprint rad,theres a small hose top right hand corner, what do i do with it blank it off ?
new to this
Re: Radiator
#18 Post by new to this »
Carledo wrote: Wed Jul 19, 2017 10:42 pm I had to cut the rad about a bit (the plastic side flanges get in the way) and you need to fabricate your own mounts. But it's nothing that would get in the way of returning it to stock at a later date.
The only other thing you need to do is fit a proper header tank with a feed pipe tee'd into the bottom hose. But this a good idea on a Sprint anyway, as the original expansion bottle is a criminally awful design and a known weakness!
Ive now got a Saab rad and header tank again from Saab,how do i plum the tank in ?,and just to make thinks a bit more tricky :D :D id like to keep the standard fan,and fit the Saab fan on the front of the rad and see if i could run the fan back wards or just turn the fan blades around how would i fix the fan to the rad
Hope you can help Dave
Re: Radiator
#19 Post by soe8m »
There also some dutch guy jeroensprint that used a ford radiator.
viewtopic.php?f=4&t=12104&start=0&st=0&sk=t&sd=a
Here one fitted in one of my sprints.
Re: Radiator
#20 Post by Carledo »
I can't, at this point in time, visualize the Saab header (i'll have a look at the one on my scrapper in the morning) I used a Volvo header on my car! But the basic idea is that you mount the header bottle as high as possible in the engine bay and wherever convenient then connect the largest and lowest hose neck on the header into the bottom radiator hose via a tee piece (try Car Builder Solutions for tee pieces) If you are lucky, you will be able to connect the extra hose neck out of the stat housing to the small (roughly 12mm) neck at the top right corner of the rad (you will need to make or obtain a hose "step down" to get over the size disparity) and connect the overflow tiny hose from the stat housing (that used to go to the expansion bottle) to the smallest and highest neck on the header. If your Saab header has any other necks, blank 'em off!
I honestly don't think you will get the Saab's electric fan onto a Sprint on EITHER side, it's just too bulky! Mine ONLY just fits and my Vauxhall engine sits a good 3" further back than a Sprint lump. If you are keeping the viscous original fan, that should be enough to get you up and running and you can ditch the viscous and go full electric with an aftermarket slimline fan at a later date. There is no point in running BOTH sorts of fan in parallel, f you need both, you have a deeper problem and are only masking the symptoms!
Okay.......
#21 Post by sprint95m »
new to this wrote: Thu Jul 20, 2017 9:37 pmSteve
Hope you can help Dave[/color]
To confirm what Steve suggested, the Saab fan assembly won't fit.
The top RH spout on the Saab radiator is necessary, plumb into the existing thermostat housing
(you need a 45 degree 11mm elbow, 16mm -11mm straight adapter and some 16mm straight hose).
viewtopic.php?f=4&t=20092
This thread details my fitting of a Saab radiator into a Dolomite 1850.
Alas the photos have gone away but it may still be of use.
I used a Volvo 850 header tank, but plumbing in the Saab one is done the same way.
Me, I won't do another Saab radiator fitting, I have went for a new Sprint rad in alloy.
The two alterations from OE I consider essential are to employ a proper header tank and use Evans Powercool 180 coolant.
SprintMWU773V
TDC Staffs Area Organiser
Re: Radiator
#22 Post by SprintMWU773V »
I like the Evans coolant concept however do be aware that it will not stop the engine running too hot. Conventional coolant will boil over thus giving you a warning sign whereas the Evans will just run very hot if you have a problem. This can still lead to warped heads and blown gaskets. Those looking to improve power should also know that waterless coolants have tended to actually reduce power due to the higher viscosity of the fluid, likewise it does not flow as well through thinner radiator tubes.
No it doesn't boil over or even pressurise under normal conditions but if your car is already running hot it will just compound the problem and not make it go away.
Aye...
#23 Post by sprint95m »
:D It is rather tempting to respond, but that would be devilment.
new to this
Re: Okay.......
#24 Post by new to this »
sprint95m wrote: Fri Jul 21, 2017 8:00 am
Ian
Thanks for the reply,any reason you didnt go with another Saab rad,and bought the alli sprint one
Thanks Dave
Re: Radiator
#25 Post by MIG Wielder »
SprintMWU773V wrote: Fri Jul 21, 2017 9:25 am I like the Evans coolant concept however do be aware that it will not stop the engine running too hot. Conventional coolant will boil over thus giving you a warning sign whereas the Evans will just run very hot if you have a problem. This can still lead to warped heads and blown gaskets. Those looking to improve power should also know that waterless coolants have tended to actually reduce power due to the higher viscosity of the fluid, likewise it does not flow as well through thinner radiator tubes.
Absolutely ! In addition because the engine runs hotter it will use more oil ( 1 1/2 pints between changes on my 1850 now ) And it will pink more on a hot day.
To quantify the difference in running temperature my 1850 used to run at 78 deg C. On a comparable quite warm day it now runs at 92 deg C. I am also aware of the higher viscosity so I don't rev; the engine until it is warmed up.
And the heater in Winter is not so good. But "adequate" rather than "good".
But the big plus points are the no pressurisation of the coolant and ( I hope ) next time I do my 1850 head gasket the studs will come straight out, as the EWC has an oily texture. And I can get 33mpg now.
So swings and roundabouts.
Yes..
#26 Post by sprint95m »
new to this wrote: Fri Jul 21, 2017 4:18 pm Thanks for the reply,any reason you didnt go with another Saab rad,and bought the alli sprint one
The weakest of the weak links in the cooling system is the so called expansion tank.
If you dump it and then properly install a header tank then there is no need to fit a different radiator.
For me making up bespoke hoses, it is a big easier to fit the Sprint radiator.
If I ever need to install an engine oil cooler there is a convenient next to the standard sized radiator.
You will however save a bit of money buying a saab radiator.
Okay.......
#27 Post by sprint95m »
For clarity
MIG Wielder wrote: Fri Jul 21, 2017 5:53 pm Absolutely ! In addition because the engine runs hotter it will use more oil ( 1 1/2 pints between changes on my 1850 now ) And it will pink more on a hot day.
As we have discussed already, you are using Classic cool 180, Tony.
This is not suitable for any Dolomite with a standard "expansion tank".
Powercool 180 is the correct version to use.
That is what I used in the 1850 without it running any hotter. BTW it is easily good for 40mpg.
:D Considering that Evans coolant has been around for decades and, after rigorous testing, is OE for several major manufacturers
the debate(?) about it amuses me.
