Crankshaft Spigot Bearing - which way round?
Bumpa
Re: Crankshaft Spigot Bearing - which way round?
#16 Post by Bumpa »
dursley92 wrote: Mon Dec 21, 2020 1:43 pm I just came across this old post and thought it might be worth adding the BL Technical Bulletin for when they were fitted on the TR7s.
They were brought in to avoid squeal problems with the phosphor bronze ones and fitted on production to all later cars.
Refarding which way round they should go, there is a seal incorporated in the bearing which should be facing the gearbox.
Looking at my photos again, the seal appears to be at the flat end, in which case I have put it in the wrong way round. Oh well, its been no trouble so far...
dursley92
#17 Post by dursley92 »
I am guessing the seal is to stop grease escaping along the shaft and contaminating the clutch (but there shouldn't be that much present anyway) OR to stop dust getting into the bearing.
Russ Cooper
Dursley
UK
