038 and 015 are the same size, the 015 has slightly more CCA and AH.Toledo Man wrote: ↑Wed Nov 08, 2017 6:39 am I'm surprised nobody's mentioned the 015. Bob, one of my local members (AKA RobSun) has a narrower battery on his Dolly 1300 so if you're reading this can you tell us which battery you had fitted?
Type 038 battery alternative..?
Re: Type 038 battery alternative..?
Holy thread revival!
I've recently replaced the battery on my 1850 and I ended up buying an 049. The plate for the clamp has to flipped 180 degrees to make it fit. It has 45Ah and 360CCA which is a bit more than the 038. It was used on quite a few Honda models.
