BW65 automatic gearbox
yorkshire_spam
Re: BW65 automatic gearbox
#16 Post by yorkshire_spam »
I'd start by picking the most appropriate speedo drive pinion for the diff ratio, then see how close the speedo is.... then get it calibrated if you can't live with it?
Walker71
#17 Post by Walker71 »
Hi Everyone,
I am on the hunt for several parts for a BW65 gearbox, hopefully someone has them lurking in their collection of spares.
They are the Spigot/Spacer/Shim/Fasteners to fit the Flexplate and Torque Convertor on a BW65 gearbox to an 1850 Dolomite engine, I also require a Speedo Drive, Gear Selector with linkage and gearbox crossmember, engine and gearbox mounts if they are NOS but if not those two parts should be available from Rimmer Bros or Quiller Triumph.
Any help gratefully received,
Phil.
#18 Post by Carledo »
I have a spigot, spacer, shim and bolts from a Sprint auto which should be good for your 1850 auto, also a gearbox crossmember and a good used original mount. Sorry no selector parts. Not sure about converter bolts , if they're in the box with the spigot....... PM me for more info.
