Fitted the Mangoletsi linkage at the weekend, instructions aren’t the clearest, but I will say that the balance bar is too wide so has to be cut down, also turn the return spring so the end around the spindle points up, if you don’t it will snag the idle screw and jam the throttle open!! Also the links that fit on the spindles rub the manifold so had to carefully shave a couple of mm off with a file.
Result, a lovely light responsive pedal!
Chris.
Dellorto throttle linkage. Very heavy pedal!
