SprintV8 going 13B Rotary
- RichardHyde
Re: SprintV8 going 13B Rotary
Hi Phill,
I see that you’re using the Sprint diff. What sort of power / torque are you expecting ?
Are you planning on using an LSD or stronger halfshafts etc ?
Thanks, Richard
Thanks, Richard
Richard
Power will be in region 250>280 Bhp (Standard RX8 231bhp)
I’ll got a Eaton M90 Supercharger from a Jaguar XJR. 4.0lt.
Which I’m hoping to fit
She still has the LSD from when it was originally built from me.
I’ve noticed Ken Clarke does strengthened half shafts.
So there’s a option if needed.
Engine mounts are 99.9% done.
Gearbox mount just needs tidying up.
Exhaust manifold again is almost finished.
Propshaft is fitted. ( Slight balls up on rear diff flange size my fault but now has the larger 27mm UJs)
Also located a Greddy large capacity Aluminium sump pan.
Still lots to do.
Still lots to do.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Not much of a update really.
With the full weight of the rotary engine and gearbox.
She’s sitting about 3 inches higher on the front.
New shorter springs ordered 2.1/4 200lbs at a starting point.
Got a Speedbox that changes a Sat Nav signal (Can also use VSS and can bus) into a mechanical rotation so I can use the original speedo.
https://www.speedhut.com/ecommerce/prod ... -Included)
Question is where did the 170mph speedo come from.
Also ordered a 10,000rpm Rev counter.
https://www.speedhut.com/gauge/GR4-TACH ... hift-light
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Revcounter arrived.
Does look really good.
Include’s shift light’s.
Max rev recall.
Factory ECU rev limiter is set at 9500.
Max rev recall.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
It looks like a Smiths Classic. Aftermarket product fom Smiths, you can get it with cable or electronic operation, I have the electronic version in the Dolomega as the Omega's speedo was driven off the ABS signal. Yours looks like a 1000TPM drive ratio, coincidentally exactly the same as the Sprint original.SprintV8 wrote: ↑Tue Oct 06, 2020 7:20 pm Not much of a update really.
PS, I'm under no illusions of being able to get mine up to 180mph! The Carledo won't go much over 115 @ 5100 rpm in 5th gear, even though the limiter doesn't cut in till 7200rpm. The aerodynamics (or lack thereof) stops it before it's anywhere near flat out.
Steve.
I’ve go no idea where the speedo come from.
I can only assume it’s always been in the Sprint but I’ve never noticed.
My goal is to get to the 170 mark LOL.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Is that BHP or MPH Phill?
If that was a genuine 3 Rotor engine we are talking 170mph+
Seriously more power than a TVR AJPV8.
Sad picked up yet another RX8 engine for parts/mocking up.
Just put some of the housings and plates together.
20B three rotor would be a major upgrade and ££££££s
https://youtu.be/jOclop23uBw
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
[color=#0000FF What fuel tank are you going to use ?
Dave[/color]
Dave[/color]
Having a new alloy tank made up.
Capacity will be the same as the Sprint or more.
Surge pot built in as well as baffled.
Original fuel cap and part filler tube.
Will sit in between rear wheel arches.
Similar to the works Escort style.
Just knocking up a CAD (Cardboard added design) one to check fitting.
Still trying to find a suitable in tank fuel pump and filter.
Or will be a inline pump and filter.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Ive ordered a fuel pump from classic Range Rover going to fit it inside the dolomite tankSprintV8 wrote: ↑Sat Dec 05, 2020 10:05 am Having a new alloy tank made up.
Are you going to baffle around the pump.
To prevent lost of fuel when cornering etc.
Hence why I having a surge pot built into the new tank.
I don’t think there’s anything on the RR pump to prevent this ?
I’m sure someone here used a pump assy from a MX5.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Phil
Ive got a 4inch diam pipe im fitting inside the tank, and the pump will sit inside the pipe,it will act a bit like a baffle for the pump
