Page 2 of 2
Re: Supercharged 1500TC
Posted: Sun Dec 20, 2020 9:33 pm
by cliftyhanger
cleverusername wrote: Sun Dec 20, 2020 8:45 pm
They managed to match the BHP of Sprint, while not loosing mid range torque? I can well believe you can get high BHP from a small NA push rod engine on carbs but usually it involves making them worse to drive on the roads because you lose all the low down power.
Put it this way, those who mod 1300 A-series engines, similar to the Triumph lump, Reckon an engine putting out 120-130bhp would be hopeless as a road engine.
Not quite sprint power, and I did say torque of a 1500 not sprint, and that is from me driving the car. Pulls way better than a 1300 ought to. But as I said, mapped ignition as opposed to clockwork and springs has big advantages.
If the A series engines are for racing, they are not interested in bottom end torque, so don't bother. They just set ignition to max 32degrees (or whatever te figure is on an A series) and good enough.
Take or leave what I have said, all I can say is the 1300 spit is much better than I expected. I ought to visit it, not seen it in 6 months. Probably be a sod to start, my missus has the knack. Then I will see if I can find a 1/4 mile app and a bit of flat road. My yellow spit did a terminal speed of 96 at Santa pod, and 15.8 seconds. I think. (It could have been 14.8, but that sounds too quick. I remember 15.8 not sure if that was first or second visit. The second time I visited I was a second quicker as I had upgraded the engine. Since then it has been mapped more accurately, and the cam control is much better)
Posted: Mon Dec 21, 2020 10:15 am
by GrahamFountain
cliftyhanger wrote: Sun Dec 20, 2020 6:51 pm it is 10:1CR, big valve head,
Checking, I misremembered my head's CR and it's only 9:1. But which 1300 head casting and stamp number gives 10:1? I can't find one that does. Or has it been skimmed for the extra compression, and if so, by how much?
Posted: Mon Dec 21, 2020 11:46 am
by cliftyhanger
GrahamFountain wrote: Mon Dec 21, 2020 10:15 am
One that has been modified. Or you can play with heads and use a 1300 low compression head on a 1500. The toledo 8.5 head works well on a 1500 with a high lift cam (cr approaching 10)
Posted: Mon Dec 21, 2020 12:32 pm
by GrahamFountain
The following image gives some interesting info on the CRs for the various heads on 1300 and 1500 engines:
It's taken from this apparently useful site:
http://auskellian.com/paul/links_files/ ... sion_Ratio
Posted: Mon Dec 21, 2020 12:41 pm
by GrahamFountain
From the data on heads in the prev post the one that looks best is the one I have off the late MkIV - casting number 312240, machining number 218142 -, having the biggest inlet valve size and smallest chamber. But I'm still not sure, with the standard cam, if there's any overall benefit from fitting HS4s.
I think, if what I had was HS4s, I wouldn't worry too much. But is it worth the cost of getting a set and the effort in fitting them?
Posted: Mon Dec 21, 2020 9:51 pm
cliftyhanger wrote: Sun Dec 20, 2020 9:33 pm
cleverusername wrote: Sun Dec 20, 2020 8:45 pm My yellow spit did a terminal speed of 96 at Santa pod, and 15.8 seconds. I think. (It could have been 14.8, but that sounds too quick. I remember 15.8 not sure if that was first or second visit. The second time I visited I was a second quicker as I had upgraded the engine. Since then it has been mapped more accurately, and the cam control is much better)
My PB in the Carledo (I have the time ticket in front of me, also from the Pod) is 16.014 @91.3mph, so your 15.8 is the more likely.
All my runs have been done on a stock SRi (130bhp) map which runs out of puff quickly after 4500rpm. I'm sure it's a mapping issue, the engine will rev to the ECU imposed limiter at 7200, but it loses interest noticeably after 4500. I reckon once it's mapped properly (a procedure i've been postponing for years) and maybe a size bigger injectors, an ET in the 14s is possible and perhaps even a TS of over 100. If I can get 14.5 or lower, i'll be a happy bunny.
Posted: Tue Dec 22, 2020 10:27 am
by cliftyhanger
Carledo wrote: Mon Dec 21, 2020 9:51 pm
My car was running about 160bhp at the event, but as the "very good map" installed by the vendor, the cam/VVT timing was rubbish. Went to a mapper the day after, who cranked it to 175, but I discovered he also didn't play with the VVT. I have poked about, and reckon it is better now.
But the 1/4 mile is a very good test of a cars "power". Way better than a rolling road, 0-60 etc. As it is easy to fudge those numbers (A chap I know reckons swinging the cam can make a big difference to numbers, but no benefit in the real world) and I could improve 0-60 by changing tyre size. 1/4 mile means the car is REALLY tested.
so was mine 16.8 and then 15.8, or 15.8 and 14.8? not too worried. Std sierra cossie is 16.6/103, so slower but higher TS. Maybe I need more practice (very likely, I have only ever done 4 runs, 2 each year) and look at gearing. Saying that, I am not likely to visit the pod in the near future. A shame Madeira Drive in Brighton is so clagged up with bollards etc thesedays. (home of Brighton Speed Trials, and also an old favourite of the street drag racers back in the 70/80s)
Posted: Tue Dec 22, 2020 12:34 pm
by jikovron
I love the sound of a 1500 with a rotund midrange pull, as an aside my experience of 3 bearing skoda cranks tells me it must all be in the metallurgy of the crank and bearings rather than the limitations of having only 3 bearings as those dont suffer the same weakness despite 60mm mains and small oil pumps.
I reckon dolomites feel stable enough to deploy 300bhp happily as I felt my 210 bhp was left wanting abit in certain situations.
Posted: Tue Dec 22, 2020 9:51 pm
cliftyhanger wrote: Tue Dec 22, 2020 10:27 am
A 15.8 @96 is believable, I think a 14.8 would give you a TS around 100-105. I'm only 0.2secs behind that, but my low TS is down to the shortage of top end power that I think was built into the factory map. The Sierra Cosworth time you mentioned is pretty anomalous in my experience, It feels like the driver wasn't getting it hooked up properly off the line, ie too much wheelspin! Or is that a 4WD Cossie? 4WD cars are known for bogging down on the launch.
I too have lost my happy hunting ground with the closure of Shakespeare County Raceway at Long Marston in 2017. Though oddly, the Carledo is always a couple of tenths quicker at the Pod. Perhaps the surface is better, also there is (or was) a prevailing headwind at Shakey since it was a disused runway.
It may sound counter intuitive, but try running with some extra weight in the boot, it helps with traction off the line. I also run the front tyres at 40psi to reduce rolling resistance and the rears at 12psi which again helps with the launch. Gearing is not so much of an issue, it's swings and roundabouts, a 4.11 will get you off the line a bit quicker, but it will promote more wheelspin in a light car and also might necessitate an extra (time sapping) gearshift further up the strip. So I stick to my economical roadgoing 3.45. Mostly, unless you miss a gear or something equally daft, a drag race is won or lost on the start line. Therefore a good time is all about a good launch. But yes, practice helps - a lot! I've been running quarters since the early 70s, still get a big kick out of it, even though my car PBs are not what they were, my old pro comp 390 '61 Galaxie, with 450+bhp would get me into the low 11s @120+.
There was a guy I used to come up against a lot at Shakey on RWYB days. A very clean and professionally turned out MkI cortina 2 door with a Zetec in it, he'd just roll onto the strip, brief linelock burnout and ease it off the line to a very consistent and apparently effortless 14.5 @107 or thereabouts. That's kinda the benchmark i'm aiming for with the Carledo. It's also pretty much why I haven't run much lately, there's not any realistic amount of time to be gained from messing about with weight and tyre pressures any more, the car is about right as is, I need more power to go faster! Until I have some, it's just a bit frustrating, being THAT close to a 15!
Posted: Wed Dec 23, 2020 8:44 am
by SprintV8
Santa Pod has more grip.
Possibly because of the more high end dragsters meetings.
You could feel the glue whilst walking around the staging area.
My Sprint with the Standard Stag V8 147Bhp made 16.2 from memory.
Rear tyres down to about 20psi.
My tweaked Hayabusa was around the 10 secs.
Posted: Wed Dec 23, 2020 9:53 am
I laughed like a drain when "Wheeler Dealers" did a '70 Dodge Charger and took it Shakey to try it out! They were over the moon with a high 17 and a low 18!
I doubt they'd have been so chuffed if i'd been there with the Carledo and p'd all over them!
But it's a good example of how car weight and aero (or lack thereof) affects real world results, the Galaxie was the same, close to 2 tons kerb weight and all the aerodynamics of a brick wall was a big hurdle to overcome that needed massive horsepower. I'ts exactly WHY I built the Carledo (which was built initially as a drag car) rather than starting with something Yank and V8.
Posted: Wed Dec 23, 2020 10:53 am
by GrahamFountain
I like Butler-Henderson's description (of the Range Rover): "all the aerodynamics of a sub post-office".
Posted: Fri Jan 01, 2021 8:31 am
by cliftyhanger
Carledo wrote: Tue Dec 22, 2020 9:51 pm [
Aha, it was 14.8
Found this video on the dreaded facebook, the first of my 2 runs. Dreadful start, still managed sub 15 and terminal of 91
https://www.facebook.com/roy.lacey/vide ... 4612458220
Posted: Fri Jan 01, 2021 9:53 am
by SprintV8
GrahamFountain wrote: Wed Dec 23, 2020 10:53 am I like Butler-Henderson's description (of the Range Rover): "all the aerodynamics of a sub post-office".
I absolutely Love Vicki. 😍😍
Don’t tell the Wife. 👍
