https://www.ebay.co.uk/itm/12v-Aeroline ... %3A2334524
If the car came with an electric pump which continually floods the carbs (annoying isn't it?) all you need is a pressure regulator. These aftermarket pumps can run anywhere up to around 7psi when the car only needs around 1.5psi. The higher pressure is more than enough to defeat the standard float needle valves and flood the carbs. Hence your problem!alvera wrote: ↑Wed Mar 10, 2021 7:31 pm I have tried everything to get this pump working.My brother in law ( Ex mechanic retired ) says it's the way I'm fitting it and I have to make sure the cam is in the right place prior to fitting.I have tried turning the engine over into various positions and even put a camera into the block but it seems the cam is not central to the hole ( it seems to be over to the left of the pump ) That's what makes me think it's a later engine requiring a longer arm.
If I can't figure this out I will have to fit a electric pump but i would like to get a better quality one than what came on the car has anyone got any suggestions and experience of fitting a decent electric pump as the one I have now continually pumps and then floods the carbs.
Should of added to post i also have a filter king fittedCarledo wrote: ↑Thu Mar 11, 2021 1:26 pmIf the car came with an electric pump which continually floods the carbs (annoying isn't it?) all you need is a pressure regulator. These aftermarket pumps can run anywhere up to around 7psi when the car only needs around 1.5psi. The higher pressure is more than enough to defeat the standard float needle valves and flood the carbs. Hence your problem!alvera wrote: ↑Wed Mar 10, 2021 7:31 pm I have tried everything to get this pump working.My brother in law ( Ex mechanic retired ) says it's the way I'm fitting it and I have to make sure the cam is in the right place prior to fitting.I have tried turning the engine over into various positions and even put a camera into the block but it seems the cam is not central to the hole ( it seems to be over to the left of the pump ) That's what makes me think it's a later engine requiring a longer arm.
The problem you are experiencing with the mechanical pump is precisely why so many have converted to electric. Generally speaking, once fitted and suitably controlled with a pressure reg, an electric pump is usually utterly reliable. They are also handy on cars that are infrequently used as the electric pump can be used to prime the carbs before cranking for easier starting. My only complaint on this score is that electric pumps, by and large, are infernally NOISY!
Folk often over estimate the fuel demands of SU carbs, for many years I ran a 2.5 litre 6 cylinder Ford Zodiac automatic fitted with 3 x 1.5" SU carbs supplied with fuel by a single SU electric pump nicked from a 1000 cc Morris Minor, which would have had, as OE, a single 1.125" SU. The setup never gave me a moments problem and no fuel starvation, even flat out in "kickdown" mode!
I'll take some pics of the install tomorrow but my pump is in the boot and the reg is under the bonnet where I can reach it easily to adjust it. TBH they both came with the car so I have no idea of make. The pump, though rubber mounted on 2 "cotton reel" mounts, is still really loud in operation and, unlike the better SU pump, runs almost continually as yours does.alvera wrote: ↑Thu Mar 11, 2021 11:27 pm Hi Steve , that sounds like a plan but like you the noise drives me mad and the pump doesn't seem to stop pumping.I have heard of a pump that fits somewhere at the rear of the vehicle which might cure the noise problem.Does your pump and regulator fit in the engine bay? I don't suppose you could send me a picture of your layout?
Regards Alan
Carledo wrote: ↑Thu Mar 11, 2021 11:59 pmalvera wrote: ↑Thu Mar 11, 2021 11:27 pm Hi Steve , that sounds like a plan but like you the noise drives me mad and the pump doesn't seem to stop pumping.I have heard of a pump that fits somewhere at the rear of the vehicle which might cure the noise problem.Does your pump and regulator fit in the engine bay? I don't suppose you could send me a picture of your layout?
Regards Alan
This may be due to the install, as electric pumps come in 2 "shades" a) short suck, long blow, designed for mounting, near the tank and b) long suck, short blow, designed for mounting near the engine. I postulate the possibility of an equal suck/blow pump for mounting centrally under the floor but i've not seen one. But if you mount the wrong pump in the right place (or vice versa) it will overwork itself and wear out quickly. Since I don't know which sort I have (and the previous owner was an incompetent bodger) I may have the pump in the wrong location!
I'm actually half inclined to splash some cash and buy a "proper" SU type pump which are only really noisy when priming the carb(s), once running they subside to a gentle occasional tick, rather than the constant thunderous drum of the one i've currently got! Maybe one designed for an MGB would do the job to an acceptable standard and noise level!
EDIT, a quick scan of ebay has produced prices of £100+ for genuine or good quality lookalke SU pumps, I may have to think again!
Hi, Clifthanger, I have looked at the Huco pumps and they look good but my carbs are Stromberg's do you think the low pressure one will be ok?cliftyhanger wrote: ↑Fri Mar 12, 2021 5:29 am Steve have a look at Huco pumps. I know a few Triumphists who have been very pleased, and these are people who are regulars on the RBRR etc etc so they have been properly tested.
The other advantage is that the Hucos come as either pull (engine bay) or push (boot mounted) and there are 2 pressure options. the low pressure works with SU's without the need for an extra regulator. Cost about £50.
The slightly cheaper option, not tried myself, is the Facet Posiflow.
Regards Alan
I am trying to remember if any of the cars I know using the Huco are on strombergs. I am unsure. But deffo OK with SU's. So do strombergs use lower pressure needle valves??alvera wrote: ↑Fri Mar 12, 2021 7:50 pmHi, Clifthanger, I have looked at the Huco pumps and they look good but my carbs are Stromberg's do you think the low pressure one will be ok?cliftyhanger wrote: ↑Fri Mar 12, 2021 5:29 am Steve have a look at Huco pumps. I know a few Triumphists who have been very pleased, and these are people who are regulars on the RBRR etc etc so they have been properly tested.
Thanks Geoff, That set up looks great, but can you elaborate on what I am seeing in place. First what is the white plastic part? then I presume a filter and then the pump.The other question is how loud is the pump ? and does it stop ticking when the carbs are full? I would like this set up but I think a better quality pump i.e a Huco and possibly a pressure regulator if needed. Kind regards Alangmsclassics wrote: ↑Sun Mar 14, 2021 7:43 am I used this setup for over a decade in my race car. Pump was less than the equivalent of 10 quid (on TradeMe - Ebay equivalent here) and was still going fine when I retired from racing. Setup in the boot was simple as it interrupted and then reconnected with the existing pipework. Getting power to the pump was the biggest issue, as for safety I wanted it controlled by a switch from the drivers seat. Admittedly car was running Dellortos not SUs but I also thought they are sensitive to high pressures. I recently fell into the trap of the arm of the mechanical pump I had to rebuild for a road car slipping off the cam on the jackshaft so was contemplating using one of these cheap electric pumps as a substitute. Geoff
