So I can envisage a number of cures,
1, fit fuel injection, this is expensive in installation and detracts from originality, but it's permanent and gives better performance, reliability and improved fuel economy. And because the fuel is constantly circulating, it's not in the rail long enough to boil, so the problem is solved.
2, get some louvres cut into the bonnet, at the back, near the bulkhead. Again, not cheap, especially when you take the painting into consideration. And not exactly original either. But they will let the hot air that would normally be stalled in front of the bulkhead out, so alleviating the fuel boiling problem and they certainly look cool as a cucumber!
3 Pop the bonnet when stationary in traffic. This really DOES work, costs nothing and doesn't detract from originality. I can testify from personal experience and experimentation that nothing bad will happen. Even driving with the catch released is not a problem till you get some speed up. At around 60mph the pressure under the bonnet will start to overcome the pressure (and weight of the bonnet itself) above it and, as if by magic, the bonnet will start to lift a bit. At around 85mph the bonnet rear edge will get up to around half way up the screen but seems to stall at this point when the pressure on both sides equalises. So, unless you are less than 5ft tall, you're probably OK!
