Rear crankshaft seal
wgcjim20
Re: Rear crankshaft seal
#16 Post by wgcjim20 »
I don't know if it's significant that 76.2mm = 3"
#17 Post by Carledo »
Is it possible, I ask myself, that there are 2 ways of measuring, fitted and unfitted?
#18 Post by Mad Mart »
When I measured the seal ID, I measured the smallest diameter which is the flexible portion, hence why I said approx.. When ordering a seal you need to know the diameter of the shaft it's fitting over. As Steve alluded to, the engineers have taken the flexible bit into account so if you order a 3" (76.2mm.) ID seal, you know it's going to fit a 3" shaft.
Adder57
#19 Post by Adder57 »
Yes I agree, and the size given for the crankshaft was 76mm so is that not the size needed. Don't understand why 76.2mm was quoted. Is there anybody who has used a double lip seal, and do they know the size etc. It would be useful for members to have this information for future reference as you don't want to be doing this Job twice.
#20 Post by Mad Mart »
FFS. I measured a used crank which was probably warn. I used a vernier to check the measurement (which isn't the most accurate tool). I may have even rounded to the nearest millimetre. The crank is going to be 3 inches, as it is imperial. 3 inches is 76.2mm.
Adder57
#21 Post by Adder57 »
Don't get mad mart. That's what I wanted to know does the seal fit the shaft. I will buy one from simply bearings and when fitted, let members know how it performs. Thanks for your time. Adder
#22 Post by Carledo »
I did wonder why all the fuss over 0.2mm! That's like 8 THOUSANDTHS of an inch! With the production tolerances the Sprint engine was built to, that's phenomenal accuracy!
#23 Post by Mad Mart »
Adder57 wrote: Sun Aug 25, 2024 1:06 pm Don't get mad mart. That's what I wanted to know does the seal fit the shaft. I will buy one from simply bearings and when fitted, let members know how it performs. Thanks for your time. Adder
Apologies. Must have gotten out of the wrong side of the bed.
Llessur
#24 Post by Llessur »
Did you ever fit the double seal? How did it perform?
